In uvm environment I want connect .sv(TB) and design in vhdl. How to represent record under record in systemverilog struct?
type abc_t is
record
valid :std_logic
data : std_logic_vector(7 downto 0);
end record;
type a is array (5 downto 0) of abc_t;
type b is array (3 downto 0) of a;
type bcd_t is
record
efg : b
end record;
There is no standard that defines the interaction between VHDL and SystemVerilog, although most simulation tools provide methods to connect the two. You will need to refer to your tool documentation or contact your tool vendor for additional assistance.
type abc_t is
record
valid :std_logic
end record;
type bcd_t is
record
efg : b
end record;
