Is this possible to make parent class member variable to be visible ONLY to immediate child and not further in inheritance hierarchy?
virtual class parent;
string s;
class child extends parent;
// s is accessible here
class grand-child extends child;
// s is NOT accessible here
In reply to bhupeshpaliwal:
It’s not possible. By default all the variables are public until they are encapsulated using identifiers like “local” or “protected”. If declared string s as protected then all the subclasses will be able to access it.
Can you please brief your purpose here.
In reply to bdreku:
I need to ensure ONLY IMMEDIATE child is able to access i.e. grand child should not able to access string s. With private/protected I am not able to achieve the same as shown below:
// Case 1: private qualifier
private string s;
// Case 2: protected qualifier
protected string s;
Am I missing something?
If you wanna the class child class to have restricted access to the variable s then you could declare it as private only in the child class removing the need to have it in the parent. Other way could be using a function to access that variable which encapsulate some sort of restricted access like looking for the parent class if not the main starting parent class then 100% is not the child. Hope i got the question. Regards
In reply to Rsignori92:
I will work out on it to see if feasible. Regards
Moving it to child class is not desired, Parent can have child-1 and child-2 … both able to access string s.
Get it i will post out something soon. Regards
I am just curious to understand more. I am getting a feeling that you are trying to implement something using the wrong ideas/tools.
What real purpose does “grand-child not accessing the variable” serve ? It’s hard for me to think of a use case that requires this.
I tried some experiments in order to break the inheritance unfortunately is not quite obvious IMO since the inheritance is still hard to break. anyway still not able to get the valid use cases honestly even if we extend from the child class you can still cast them in order to make them compatible to the parent class.
the structure is generally speaking this one:
- parent
- 2. child
[list=1]
3. g-child
[/list]
going from bottom to top you are going to find the same parent even if you declare a variable to be local for instance assigned by a function which will check the parent from where the class is derived this approach is still broken since by casting you will still allow the access. Why not simply change the approach since your problem could be fixed in different way simply do not use the same class and derive them. Regards
