But, when i remove the logic from the module A interface, everything is o.k.
Can anyone explain why i have this error, and how can i fix it without changing the dut?
I tried to use modports, but it didn’t help.
Thanks for your help.,
The error that you are getting is not correct. Please check the version of the tool that you are using and contact your vendor. There is no difference between
module A (
input logic [31:0] addr
and
module A (
input [31:0] addr
because they both declare ports that are implicitly ‘wire’. The first has an explicit data type 'logic, and the second has an implicit data type ‘logic’. See section 23.2.2.3 Rules for determining port kind, data type, and direction in the 1800-2012 LRM.
However, you can change the way you instantiate your dut to:
module tb;
A a(io_if.addr);
dut_io io_if();
Thank you Dave,
I use latest version of VCS (L-2016.06-1). I tried with different versions, but still getting the same error:
Error-[VIPCBD] Variable input ports cannot be driven
tb.sv, 25
Variable input ports cannot be driven.
The input variable port “addr” of module “A” cannot be driven.
Source info: assign tb.a.addr = tb.io_if.addr;
Module ‘A’ is defined at “tb.sv”, 1
Unfortunately, I can’t use your suggestion in our TB without modifying a lot of files.
Maybe i’m missing some flags. I used the following command for this example:
vcs -lca -sverilog tb.sv
I opened a case to Synopsys, and this is the answer I got. Thought it might help to someone else.
You can see below (LRM) that Assignments to variables declared as input ports shall be illegal.
23.3.3.2 Port connection rules for variables If a port declaration has a variable data type, then its direction controls how it can be connected when instantiated, as follows:
— An input port can be connected to any expression of a compatible data type. A continuous assignment shall be implied when a variable is connected to an input port declaration. Assignments to variables declared as input ports shall be illegal. If left unconnected, the port shall have the default initial value corresponding to the data type.
When you have logic inside the port declaration of addr, addr become variable (not net). When you omit logic, addr become net and it legal to assign to it directly.
You can do two experiments to see that without logic, addr become wire (net).
module A (
input [31:0] addr ///<— omit logic
//input logic [31:0] addr
In reply to stas2005:
But the port is a net, not a variable. See section 23.2.2.3 Rules for determining port kind, data type, and direction (“kind” is net or variable)
If the port kind is omitted:
For input and inout ports, the port shall default to a net of default net type. The default net type can be changed using the `default_nettype compiler directive (see 22.8).
For output ports, the default port kind depends on how the data type is specified:
- If the data type is omitted or declared with the implicit_data_type syntax, the port kind shall default to a net of default net type.
- If the data type is declared with the explicit data_type syntax, the port kind shall default to variable.
Since this an an input port with the port kind omitted, it is a net.
module A (
wire [31:0] addr; ///<---- No error! legal logic [31:0] addr; ///<— ERORR! Ilegal
wire [31:0] addr_local;
assign addr_local = addr;
