I want to write an assertion where genclock must rise in the setup or hold time window(say 2ns each) of refclock. Is there a in built timing check for this?
Your text to link here…
In reply to soh2415:
Hey, so generally speaking SVA are not intended to be used to check timing, I’d recommend using the Systemverilog timing system task like $setup $hold $width and $period.
My suggestion is to create a module called timing check and encapsulate those tasks into a specify endspecify. All those tasks, mainly setup and hold (which i believe are the ones you should be using) provide and output called notifier. You can use this bit to check if the timing constraint has been violated.
In reply to Rsignori92:
Can you specify a code. I have gone through timing checks but not getting clarity
Here is an example that you can use as a guideline:
 module top2(output logic clk, d);
    `include "uvm_macros.svh"
    import uvm_pkg::*;
    timeunit 1ns;  timeprecision 100ps;
    logic a, d1;
    bit[1:0] delay;
    realtime duration= 2.0ns;
        clk=0;
        forever #5 clk = !clk;
    always @(posedge clk) begin
        if (!randomize(a, delay) with {
           delay  dist {2'b01 := 1, 2'b11 := 1};
          }) `uvm_error("MYERR", "This is a randomize error");
          #delay d<=a;
    property hold_chk;
        realtime clock_sample;
         @(posedge clk)
        (1,clock_sample = $realtime)##0 (1,$display("clock_sample=%0t",clock_sample)) |->
        @(d)((1,$display("data_sample=%0t,difference=%0t",$realtime,$realtime-clock_sample))##0
        ($realtime - clock_sample) >= duration);
    endproperty : hold_chk
    HOLD_CHK : assert property (hold_chk)
        // $display("****ASSERTION_PASSED**** clock");
        	$display ("%0t ERROR Hold****",$realtime);
            property setup_chk;
                 @(d)
                (1,clock_sample = $realtime)##0 (1,$display("d_sample=%0t",clock_sample)) |->
                @(posedge clk)((1,$display("clk_sample=%0t,difference=%0t",$realtime,$realtime-clock_sample))##0
            endproperty : setup_chk
            SETUP_CHK : assert property (setup_chk)
                    $display ("%0t ERROR setup****",$realtime);
    setup_time_check setup_time_check1(clk, d);
    initial #2000 $finish;
  3. Papers:
Wrong model, here is another one:
 module top();
    import uvm_pkg::*;
    logic  a, clk=0;
    bit[1:0] delay;
    realtime duration=2ns;
    initial forever #5 clk = !clk;
    assign   #delay d = a;
    specify
        //$setuphold(posedge clk, d, -1, 2);
     endspecify
    property hold_chk;
         @(posedge clk)
        (1,clock_sample = $realtime) |-> @(d) ($realtime - clock_sample) >= duration;
        $display("****ASSERTION_PASSED");
            $display ("%0tERROR****The value of d is %b",$realtime, $sampled(d));
            property hold_chk1;
                @(posedge clk) (1,clock_sample = $realtime) |->
                endproperty : hold_chk1
                HOLD_CHK1 : assert property (hold_chk1);
 module setup_time_check(input clk, data);
    let tSU=2ns;
    let tHLD=2ns;
    bit notifier1;
    specify
        $width(posedge clk,5);
        $period(posedge clk,10);
    /* $setuphold ( reference_event , data_event , timing_check_limit , timing_check_limit
         [ , [ notifier ] [ , [ timestamp_condition ] [ , [ timecheck_condition ]
         [ , [ delayed_reference ] [ , [ delayed_data ] ] ] ] ] ] ) ; */
         $setuphold( posedge clk, data, tSU, tHLD, notifier1 );
     endspecify
    import uvm_pkg::*;
    logic a, d1;
    bit[1:0] delay;
        clk=0;
         if(randomize(a, delay));
    	#delay d<=a;
     property hold_chk;
         @(posedge clk)
        ($realtime - clock_sample) >= duration ) ;
        	$display ("%0tERROR****",$realtime);
  3. Papers:
Include this in your module. This checks for the violations.
  specify
      $setup(gen_clk, posedge ref_clk, 2);
      $hold(posedge ref_clk, gen_clk, 2);
   endspecify
