Wrong model, here is another one:
module top();
`include "uvm_macros.svh"
import uvm_pkg::*;
logic a, clk=0;
bit[1:0] delay;
realtime duration=2ns;
initial forever #5 clk = !clk;
always @(posedge clk) begin
if (!randomize(a, delay) with {
delay dist {2'b01 := 1, 2'b11 := 1};
}) `uvm_error("MYERR", "This is a randomize error");
assign #delay d = a;
specify
//$setuphold(posedge clk, d, -1, 2);
endspecify
property hold_chk;
realtime clock_sample;
@(posedge clk)
(1,clock_sample = $realtime) |-> @(d) ($realtime - clock_sample) >= duration;
endproperty : hold_chk
HOLD_CHK : assert property (hold_chk)
$display("****ASSERTION_PASSED");
else
$display ("%0tERROR****The value of d is %b",$realtime, $sampled(d));
property hold_chk1;
@(posedge clk) (1,clock_sample = $realtime) |->
endproperty : hold_chk1
HOLD_CHK1 : assert property (hold_chk1);
setup_time_check setup_time_check1(clk, d);
initial #2000 $finish;
module setup_time_check(input clk, data);
let tSU=2ns;
let tHLD=2ns;
bit notifier1;
specify
$width(posedge clk,5);
$period(posedge clk,10);
/* $setuphold ( reference_event , data_event , timing_check_limit , timing_check_limit
[ , [ notifier ] [ , [ timestamp_condition ] [ , [ timecheck_condition ]
[ , [ delayed_reference ] [ , [ delayed_data ] ] ] ] ] ] ) ; */
$setuphold( posedge clk, data, tSU, tHLD, notifier1 );
endspecify
module top2(output logic clk, d);
import uvm_pkg::*;
logic a, d1;
bit[1:0] delay;
realtime duration= 2.0ns;
clk=0;
if(randomize(a, delay));
#delay d<=a;
property hold_chk;
@(posedge clk)
(1,clock_sample = $realtime)##0 (1,$display("clock_sample=%0t",clock_sample)) |->
@(d)((1,$display("data_sample=%0t,difference=%0t",$realtime,$realtime-clock_sample))##0
($realtime - clock_sample) >= duration ) ;
$display("****ASSERTION_PASSED**** clock");
else
$display ("%0tERROR****",$realtime);
Real Chip Design and Verification Using Verilog and VHDL($3) Amazon.com - Papers:
Verification Horizons - July 2020 | Verification Academy - SVA Alternative for Complex Assertions
