How to write Assertions for timing registers
I need to write assertions for timing registers ex:
reg [3:0] thv_count;
thv_count = (23*clk_period);
Assertion: assert property(@(posedge clk)) ($rose(FLASH.prog) && (rose(FLASH.erase)) |-> ##[thv_count : ] ($rose(FLASH.nvstr));
clk_period keeps changing.
For the above code i am getting an error as illegal operand for constant expression. i cannot use reg value at constant expression. please let me know how to solve the error.
This should work:
module clk_period;
	logic [3:0] thv_count;
	int clk_period=10;
	bit clk;
	default clocking cb_ck1 @ (posedge(clk));  endclocking
	initial forever #10 clk=!clk;
	assign thv_count = (23*clk_period);
//  assert property(@(posedge clk)) ($rose(FLASH.prog) && ($rose(FLASH.erase)) |->
//     ##[thv_count : $] ($rose(FLASH.nvstr));
	property p_flash;
		logic [3:0] v_thv_count;
		($rose(FLASH.prog) && ($rose(FLASH.erase)), v_thv_count=0) |=>
		(1, v_thv_count=v_thv_count+1'b1)[*1:$] ##1 v_thv_count==thv_count // get to thv_count
		##[0:$] ($rose(FLASH.nvstr)); // changed from ##[1:$]
Ben Cohen, Design and verification expert (310) 997-2187
  • SystemVerilog Assertions Handbook, 3rd Edition, 2013 ISBN 0-9705394-3-6
  • Component Design by Example, 2001 ISBN 0-9705394-0-1
Note: If the value of thv_count changes during the assertion, and one needs to capture the value of that variable during a nonvacuous attempt, then you would need to save the value of that variable into a local variable. Thus,
module clk_period;
	int clk_period=10;
	bit clk;
	property p_flash;
		logic [3:0] v_thv_count, v_count_hold;
		($rose(FLASH.prog) && ($rose(FLASH.erase)), v_thv_count=0, v_count_hold=thv_count) |=>
		(1, v_thv_count=v_thv_count+1'b1)[*1:$] ##1 v_thv_count==v_count_hold // get to thv_count
Hi Ben,
Thanks for replying to the query,
property a4;
logic [15:0] v_Tnvh_count;
@(posedge clk)(fell(FLASH.erase), v_Tnvh_count=0) |=> (1, v_Tnvh_count=v_Tnvh_count+1'b1)[*1:] ##1 (v_Tnvh_count == Tnvh_count) ##[1:$] ($fell(FLASH.nvstr));
endproperty : a4
Assertion4: assert property (a4);
problem here is this assertions is getting activated at every posedge of clk and waiting for $fell(FLASH.erase) event, but this event occurs only once, assertion finishes and gets activated again in the next clk cycle, hence assertion is failing. how do i avoid un necessary failing of assertion
In reply to sahmed01:
I am not totally clear on your issue. Perhaps the following will clarify things:
  1. An assertion is attempted at every clock edge.
  2. an assertion of the form (sequence1 |=> sequence2) has an antecedent (the sequence1) and a consequent.
  3. If in that attempt the antecedent if false then the assertion in vacuous.
    However, if in that attempt the antecedent is true then the consequent is evaluated.
    You say “problem here is this assertions is getting activated at every posedge of clk and waiting for $fell(FLASH.erase) event”. That is true for every attempt. Thus, are you saying that at every clock you have a $fell(FLASH.erase)? Obviously not possible. So that the evaluation of the assertion for that attempt where $fell(FLASH.erase) is true, the waiting for the consequent is OK.
Now you say “assertion finishes and gets activated again in the next clk cycle, hence assertion is failing. how do i avoid un necessary failing of assertion”. That implies that you have a new fell(FLASH.erase). First, because of the ##[1:], the assertion can never fail, but only succeeds.
Second, if you are trying to have only a one-shot type of an assertion that has a true antecedent until that assertion completes, you can do one of several things, but the simplest would be to create a flag that turns on when $fell(FLASH.erase)==1, and turns off when the assertion succeeds; you can use an action block. The flag is added to the antecedent as another precondition.
If it is desired to fire one assertion that has a true antecedent until its outcome is determined, you can use a semaphore. Below is an example of this base on your model.
Note tha in this model the assertion can never fail because of the ##[1:$]
module clk_period;
	int clk_period=10;
	bit clk, flag;
	// Semaphore
	function void set_flag();
	    flag=1'b1;
	endfunction : set_flag
	property p_flash;
		(!flag && $rose(FLASH.prog) && ($rose(FLASH.erase)), v_thv_count=0, set_flag()) |=>
		##[1:$] ($rose(FLASH.nvstr));
	ap_flash: assert property( p_flash) flag<=1'b0;
I am getting this error, what does it mean and wat do i do
@(posedge clk)(($stable(YADR) && stable(DIN)), v_Tads_count=0) |=> (1, v_Tads_count = v_Tads_count+1'b1)[*1:] ##1 v_Tads_count == Tads_count ##[1:$] ($rose(YE));
ncsim: *E,ASRTST (…/tb_top/assertions.sva,180): (time 8115680 PS) Assertion top_tb.t1.Assertion13 has failed (182 cycles, starting 0 FS)
Please help
Your assertion should never fail because of ##[1:]. It can either be vacuous if the antecedent is false, or it can succeed if the consequent is true. Below is a modified code that models the structure of what you have (I used "a" and "b" to reflect your expressions. Try this code in ncsim. Questa showed a single success at 2050ns Also try different variations, like (1, v_count=v_count+1)[*1:] ##1 v_count==count; // ##[1:$] b;
module rep0;
	bit clk, a=0, b=0;
	int count;
	// @(posedge clk)(($stable(YADR) && $stable(DIN)), v_Tads_count=0) |=>
	// (1, v_Tads_count = v_Tads_count+1'b1)[*1:$] ##1 v_Tads_count == Tads_count ##[1:$] ($rose(YE));
	property p_count;
		int v_count;
		($rose(a), v_count=0) |=>
		(1, v_count=v_count+1)[*1:$] ##1 v_count==count ##[1:$] b;
	endproperty : p_count
	ap_count : assert property(p_count);
		repeat (2)  @ (posedge clk);
		a <= 1'b1;
		count <= 5;
		repeat(100) @ (posedge clk);
		b <= 1'b1;
endmodule : rep0
Ben,
property a9;
int v_Twpr_count;
($fell(YE) && $fell(SE) && fell(NVSTR),v_Twpr_count=0) |=> (1, v_Twpr_count = v_Twpr_count+1)[*1:] ##1 v_Twpr_count == Twpr_count ##[1:$] ($rose(ERASE) || $rose(PROG));
endproperty : a9
Assertion9 : assert property(a9);
for the above code, assertions are getting activated on the 1st clk tick itself, but the actual scenario i need to check is: as soon as YE, SE and NVSTR goes low, need to wait for minimum Twpr_count system clk cycles before program or erase operation take place. How do i avoid this from happening.
(AT 0 simulation time all register values are zero)
Code below will do the trick. Fire the assertion after the desired number of clocks.
Key here is this
        repeat (Twpr_count) @ (posedge clk);
        go <= 1'b1; // flag for debug, not needed otherwise
        forever @ (posedge clk) Assertion9 : assert property(a9);
Test code
module testset;
    bit clk, go, YE, SE, NVSTR, ERASE, PROG;
    int Twpr_count=16;
    default clocking cb_clk @ (posedge clk);  endclocking
    property a9;
        int v_Twpr_count;
        ($fell(YE) && $fell(SE) && $fell(NVSTR),v_Twpr_count=0) |=>
        (1, v_Twpr_count = v_Twpr_count+1)[*1:$] ##1 v_Twpr_count == Twpr_count ##[1:$] ($rose(ERASE) || $rose(PROG));
    endproperty : a9
        go <= 1'b1;
    always  @ (posedge clk)  begin : aly
        #2 if(!randomize(YE, SE, NVSTR, ERASE, PROG))  $error("randomization failure");
    end  : aly
//for the above code, assertions are getting activated on the 1st clk tick itself,
// but the actual scenario i need to check is: as soon as YE, SE and NVSTR goes low,
// need to wait for minimum Twpr_count system clk cycles before program or erase operation take place.
// How do i avoid this from happening.
//(AT 0 simulation time all register values are zero)
endmodule : testset
repeat (Twpr_count) @(posedge clk);
ncvlog: *E,SFLPIN (…/tb_top/assertions.sva,180|13): Procedural code in initial block containing concurrent assertions.
property a9;
int v_Twpr_count;
endproperty : a9
bit go;
go <= 1’b1;
forever @(posedge clk) Assertion9 : assert property(a9);
in the above code Assertion9 is triggered after Twpr_count ? If yes then this will not serve our purpose right. what if YE SE and NVSTR signal goes low during Twpr_count, will that be not missed. please clarify.
thanks
Two issues:
  1. If the NcSim tells you that the following is a bug, then NcSim is in error.
    Per the LRM, it is legal to have concurrent assertions in an initial block. If fact the code I gave you before ran OK in Questa. It is illegal to have a concurrent assertion in the final block.
ncvlog: *E,SFLPIN (../tb_top/assertions.sva,180|13): Procedural code in initial block containing concurrent assertions.
  1. Sorry, I missunderstood you initially. What you had is OK.
property a9;
int v_Twpr_count;
($fell(YE) && $fell(SE) && $fell(NVSTR),v_Twpr_count=0) |=> (1, v_Twpr_count = v_Twpr_count+1)[*1:$] ##1 v_Twpr_count == Twpr_count ##[1:$] ($rose(ERASE) || $rose(PROG));
endproperty : a9
If the simulator thinks that there is a $fell at time 0 then your simulator is in error.
However, for your case, you could simply change the repeat to 1 cycle. Thus,
repeat (1) @(posedge clk); // or simply @(posedge clk);
go <= 1'b1;
Ben Cohen systemverilog.us
If initial gives you trouble (this is an NcSim issue if it is), then do the following:
bit start;
   if (!start) start <= 1'b1;
   else  Assertion9 : assert property(a9);
Still it is pointing error, if it is simulator error, what do i do? how do i avoid this?
property a9;
int v_Twpr_count;
endproperty : a9
bit start;
if (!start) start <= 1’b1;
ERROR:
ncvlog: *E,SFLPCN (…/tb_top/assertions.sva,191|4): Procedural code in always block containing concurrent assertions.
bit start;
ERROR:
Going back to SystemVerilog 3,1 (in 2003)
17.12 Concurrent assertions
A property on its own is never evaluated for checking an expression. It must be used within a verification statement for this to occur. A verification statement states the verification function to be performed on the property. The statement can be one of the following:
— assert to specify the property as a checker to ensure that the property holds for the design
— cover to monitor the property evaluation for coverage
A concurrent assertion statement can be specified in:
— an always block or initial block as a statement, wherever these blocks can appear
— a module as a module_or_generate_item
— an interface as an interface_or_generate_item
— a program as a non_port_program_item
— $root
You need to talk to Cadence as to why they have not supported this SVA requirement. This is not even 2009 feature! It’s a 2003 feature.
Ben Cohen SystemVerilog.us
Since NcSim is giving you grief with procedural concurrent assertion, you could, in some circumstances, have procedural code to write flags that can be used by concurrent (non-procedural) assertions. Thus, for the above problem:
bit start;
else Assertion9 : assert property(start |-> a9);
However, one would lose a lot of capabilities in not being able to write procedural concurrent assertions.
Ben Cohen http://www.systemverilog.us/
  • Using PSL/SUGAR … 2nd Edition
  • Cmpt Design by Example
  • VHDL books
I did an inquiry with Cadence and it looks like NcSim does support procedural concurrent assertions. A response: "If your question is for concurrent assertions in procedural block, its supported in ncsim. One has to us a (compile-time) switch –procsva ".
Ben systemverilog.us
property a3;
reg [15:0] v_Tnvs_count;
(rose(ERASE),v_Tnvs_count=0) |=> (1, v_Tnvs_count = v_Tnvs_count+1'b1)[*1:] ##1 (v_Tnvs_count == Tnvs_count) ##[1:$] ($rose(NVSTR));
endproperty : a3
Assertion3 : assert property (a3);
how can i add V_Tnvs_count to simvision. I want to see how this signals will behave at each clk
Thanks-
As the scope of the signal is within the property, how do i dump that signal into simvision?
Thanks-
Viewing the local variables of a property is a function of the debugging tools, and is vendor dependent. I have Questa, and with Questa one can use the Assertion Thread Viewer (ATV) that provides the values of the local variables. I have not used NcSim for a long time.
Ben SystemVerilog.us
