How to write a assertion to check no of pos edges of a clock within 120ns from trigger condition
I need help to write an assertion for following,
-We have 2 signals a & b.
-Falling of signal ‘a’ is triggering condition.
-From the fell of ‘a’, count no of pos edges of signal ‘b’ within 120ns.
-if count(no of pos edges of ‘b’ less than or equal to two assertion should fail, else (>2) assertion should pass
-Assertion should be active at all times
Be cause you have an analog type of requirement (the 120ns). I would use tasks, as described in my paper,link below.
task automatic t_AB;
   bit status;
   int count:
  if ($fell(a))
     begin : the120ns
      #120ns
     begin : thecount
      // count the b's
      Statis=1: // under count values
    join_any
    assert(status);
always @(posedge clk)
   fork t_AB();
   join_none
Above is a framework for your code, you need to tune it.
See my paper 1) SVA Alternative for Complex Assertions
Verification Horizons - March 2018 Issue | Verification Academy
  1. Verification Horizons - March 2018 Issue | Verification Academy
  2. SVA: Package for dynamic and range delays and repeats | Verification Academy
I am new to writing SVA assertions. This might not be 100% correct, I am just thinking this from a logic perspective on how to write it as of now.
bit status;
int count:
if ($fell(a))
begin : the120ns
//#120ns: //wait till timeout
`uvm_do_with(delay, {delay == 12000;}); //put some delay here equivalent to 120 ns units. can be a delay sequence too like here.
 begin : thecount
  // count the b's
   //@(posegde clk) // the process inside fork is already spawned  on a posedge clk.
   $rose(b)|->(count ++);
join_any
assert(count>=2);
fork t_AB();
join_none
bit status;
int count:
if ($fell(a))
begin : the120ns
#120ns
begin : thecount
// count the b's
join_any
assert(status);
fork t_AB();
join_none
Browse all content in Verification Academy: Articles, Cookbooks, Resources, Sessions, and Tracks
  1. Browse all content in Verification Academy: Articles, Cookbooks, Resources, Sessions, and Tracks
  2. SVA: Package for dynamic and range delays and repeats - SystemVerilog - Verification Academy
Hi Ben,
In your code I see that on every posedge clk, the task is called under a fork. This will just create multiple threads. Instead of this can’t we just move the alywas @posedge clk internal to the mutiple processes running inside fork .join. something like this:
bit status;
int count:
bit a_fall;
always@(posedge clock) begin: block_to_disable
if ($fell(a)) begin
a_fall = 1;
disable block_to_disable;
begin : the120ns
#120ns: //wait till timeout (excute a delay sequence here that waits till 120ns)
begin : thecount
// count the b’s
always@(posegde clk)
join_any
assert(count>=2);
fork t_AB();
join_none
Here are the 2 solutions, one woth the task approach and one woith SVA.
This is a complete testbench for the assertions.
    timeunit 1ns;     timeprecision 100ps;
    bit clk, a, b;
    event e_pass, e_fail;
        initial forever #10 clk=!clk;
        // -Falling of signal 'a' is triggering condition.
        // -From the fell of 'a', count no of pos edges of signal 'b' within 120ns.
        // 120ns is 6 clk periods
        // -if count(no of pos edges of 'b' less than or equal to two
        //      assertion should fail, else (>2) assertion should pass
        function int do_count (int d, bit b);
            if($rose(b)) return d+1'b1;
            else return d;
        property p_a2b;
            int v_count=0;
            $fell(a) |-> ( (1, v_count=do_count(v_count, b))[*1:$]  intersect (1[*7]))
            ##0 v_count > 2;
        // the (1[*7])) account for the start repeat + 6 more
        ap_a2b: assert property(@ (posedge clk) p_a2b );
            automatic bit  status=0;
            automatic int  count=0;
                begin : the120ns
                    #120ns;
                begin : thecount
                    forever begin : fr1
                        // count the b's
                        @(posedge clk);
                        if($rose(b)) count=count+1'b1;
                        if(count>2)status=1;
                    end : fr1
            join_any
            if(status) -> e_pass;
            else -> e_fail;
            assert(status);
         if ($fell(a)) fork t_AB();
          join_none
            bit va, vb;
            repeat(300) begin
                @(posedge clk);
                if (!randomize(va, vb)  with
                { va dist {1'b1:=1, 1'b0:=10};
                vb dist {1'b1:=1, 1'b0:=1};
            a <= va;
            b <= vb;
        $stop;
    FREE BOOK: Component Design by Example
    … A Step-by-Step Process Using VHDL with UART as Vehicle
    http://systemverilog.us/cmpts_free.pdf
Made an edition in the function to make it inclusive of all needed arguments. This insures that all needed variables are sampled correctly, and it enhances readability. In general, it is better to avoid side-tear effects when using functions.
The function header is now
// did not have the "bit b" before
Ben
HI Ben ,
i think above assertion code can be used with modification for checking the following condition
  1. 128 iterations of clock pattern(16 posedge clock cycles followed by 8 cycles of clock should be absent) with clock period of 500ps
  2. if less then 16 iterations are found … then it should throw error .
type or paste code here
        // -From the fell of 'a', count no of pos edges of signal 'b' within 7500ps.
        // 7500ps is 16 clk periods
        // 4000ps 8clk period --> absent
        //      assertion should fail, else (>16) assertion should pass
            else return d;
        property p_a2b;
            int v_count=0;
            $fell(a) |-> ( (1, v_count=do_count(v_count, b))[*1:$]  intersect (1[*16]))
            ##0 v_count > 16;
1) how to check for 8 clock cycle absent & 128 iterations .. can you help me on this .
Regards
rohit
[Ben] 1) You have a situation where if($fell(a)) then
- You have 128 iterations of 16 cycles of clocks _ 8 time cycles of no clocks.
- Within each iteration you assert the existance of 2+ rose(b)
- After all the 128 iterations, you assert the existance of 16+ rose(b)
2) SVA needs clocks to work (model uses "clk").  Using a TB clock (e.g., "clkr") cannot test the clk.
3) If you have ONE iteration, you can use SVA for the test of rose(b) in 16 cycles,
   and then thru the sequnce_match_item, call a task to check the lack of clocks.
In https://www.edaplayground.com/x/vaVy       // untested
I tried looping the property 128 times, byt was reminded that
// Delays or wait statements in match item task calls are not supported.
The core of the code is:
        else return d;
    // My property for these requirements:
    // @ fell(a) we have 16 posedge clk. "b" must change to 1'b1 twice or more.
    // Following the 16 posedge, we must check for 4000ps of no clocks.
    property p_a2b;
        int v_count=0, v_total=0;
        $fell(a) |->
        (((1, v_count=do_count(v_count, b), v_total=do_count(v_total, b))[*1:$]  intersect (1[*16]))
         ##0 (v_count >=2, t_AB())); // [*128]  ##0 v_total>16;
      // are not supported.
    // [Ben] ?? the (1[*7])) account for the start repeat + 6 more
    ap_a2b: assert property(@ (posedge clk) p_a2b ) p1++; else f1++;
    task automatic t_AB();
        automatic int  err=0;
            begin : the4000ps
                #4000ps;
            begin : thecount
                forever begin : fr1
                    @(posedge clk) err=1;
                end : fr1
        join_any
        assert(err);
4) To do the 128 interations that include cycles with clk, and cycles without clk,
   you have to use tasks.
   https://www.edaplayground.com/x/8pxN       // untested
   (In this code, I used 12 iterations instead of 128)
    always_ff @(posedge clk) begin
        if($fell(a))  t_ab_iteration();
    task automatic t_ab_iteration(); // p_a2b;
        int v_count=0, v_total=0;  // task called at $fell(a)
        repeat(128) begin : iterations // change 12 to 128
            repeat(16) begin : repeat16
              @(posedge clk) if($rose(b)) begin : the16cyles
                v_count++; v_total++;
              end: the16cyles
            end :repeat16
            t_noclk8(); // check for noclocks in 4000ps
            am_2in16: assert(v_count >=2); // check count per iteration
            v_count=0; // reset iteration count for rose(b)
        end : iterations
        // (((1, v_count=do_count(v_count, b), v_total=do_count(v_total, b))[*1:$]  intersect (1[*16]))
        // ##0 (v_count >=2, t_AB()))[*128]  ##0 v_total>16;
        am_16intoral: assert(v_total >=16); // check count per iteration
    task automatic t_noclk8();
        int  err=0;
            begin : the4000ps
                #4000ps;
            begin : thecount
                forever begin : fr1
                end : fr1
        join_any
        assert(err);
   Ben@systemverilog.us
   https://systemverilog.us/vf/Cohen_Links_to_papers_books.pdf
If you have a clk disable signal, you can use that signal in SVA instead of calling a task, thus keeping the whole assertion in SVA.
You can then use the assertion in FV.
