In the below code, I am trying to connect the inout port member(data) of virtual interface(device_if) from device class to the inout port(data) of device_top module using “tran” keyword. But it is not working.
As per my knowledge, the possible ways of making the inout port connection for above case are,
Instead of declaring signals on the device_top module port list, we can declare device_if interface on the module port list and make interface connection to class vif.
Or
In the device_top module, depending on the cmd and cmd_enable signals, identify the data direction and assign the values accordingly on inout port.
But, How can I do direct connection of inout port signal without adding device_if declaration on device_top module or depending on the data direction?
Thanks.
Code:
timescale 1ps/1ps
interface device_if(input clk, input reset);
logic cmd_enable;
logic cmd;
wire [7:0] data;
logic [7:0] data_reg = 'z;
assign data = data_reg;
modport dev(
input cmd_enable,
input cmd,
input data,
output data_reg
modport host(
output cmd_enable,
output cmd,
inout data
endinterface
class device;
virtual interface device_if.dev vif;
bit[7:0] mem;
task run();
forever begin
@(posedge vif.clk);
if(vif.reset == 0 && vif.cmd_enable == 1 && vif.cmd == 1/*WRITE*/) mem <= vif.data;
else if(vif.reset == 0 && vif.cmd_enable == 1 && vif.cmd == 0/*READ*/) vif.data_reg <= mem;
module device_top(input clk, input reset, input cmd_enable, input cmd, inout data); // we must have these inout/input signals in the port list and must not declare device_if interface in the port list
device_if dev_if;
assign dev_if.cmd = cmd;
assign dev_if.cmd_enable = cmd_enable;
**//tran(data, dev_if.data); // not working. How to connect interface inout signal to module port inout signal?**
device dev;
dev = new();
dev.vif = dev_if;
dev.run();
Hi Ben,
Thanks for sharing link, the info is helpful. I have tried multiple iterations to make the inout port connection working with simple declarations like it was done for input/output signals.
So, instead of using "tran" keyword for inout connection, I have used two separate assign statements to connect the interface inout signal to module port inout signal on write and read direction respectively. This resolves my issue. Given Below the working code snippet.
Thanks.
Working Code:
`timescale 1ps/1ps
logic cmd_enable;
logic cmd;
logic [7:0] addr;
wire [7:0] data;
modport dev(
input clk,
input reset,
input cmd_enable,
input cmd,
input addr,
input data,
output data_reg
// modport host(
// output cmd_enable,
// output cmd,
// inout data
typedef enum bit[1:0] {NOP, READ, WRITE} command_t;
command_t cmd_enum;
assign cmd_enum = cmd_enable ? (cmd ? WRITE : READ) : NOP;
endinterface
class device;
bit[7:0] mem [bit[7:0]];
task run();
forever begin
@(posedge vif.clk);
if(vif.reset == 0 && vif.cmd_enable == 1 && vif.cmd == 1/*WRITE*/) mem[vif.addr] = vif.data;
else if(vif.reset == 0 && vif.cmd_enable == 1 && vif.cmd == 0/*READ*/) vif.data_reg <= mem[vif.addr];
else vif.data_reg <= 'z;
`timescale 1ps/1ps
module device_top(input clk, input reset, input cmd_enable, input cmd, input logic [7:0] addr, inout [7:0] data); // we must have these inout/input signals in the port list insead of declaring device_if interface in the port list
device_if dev_if(clk, reset);
assign dev_if.addr = addr;
//tran(data, dev_if.data); // NOT WORKING!! How to connect interface inout signal to module port inout signal?
assign dev_if.data = data; // WORKING!!! wr data from host transfered to device
assign data = dev_if.data_reg; // WORKING!!! rd data from device transfered to host
device dev;
dev = new();
dev.vif = dev_if;
dev.run();
