I want to check a signal to be high for n clocks where n can be configurable local variable
module m;
bit clk, a, b;
int g=5;
property p_g;
int v;
($rose(a), v=g) |-> (1'b1, v=v-1'b1)[*1:$] ##0 v==1'b0;
ap_g: assert property(@ (posedge clk) p_g);
Ben Cohen http://www.systemverilog.us/
- SystemVerilog Assertions Handbook, 3rd Edition, 2013
- A Pragmatic Approach to VMM Adoption
- Using PSL/SUGAR … 2nd Edition
- Real Chip Design and Verification
- Cmpt Design by Example
- VHDL books
Hi Ben,
I think above property does not check whether Signal a reamins high for all 5 clocks so can we write this as
(rose(a), v=g) |-> (a==1'b1, v=v-1'b1)[*1:] ##0 v==1’b0 ##0 a==1’b1;
Thanks & Regards
Raku
In reply to raku:
You’re correct, my mistake.
Thanks for the update
Ben
(a==1’b1, v=v-1’b1) this will work as an and ? what is purpose of ##0’s . We can not do it using $stable?
Chandru
In reply to Chandrashekhar Goudar:
(a==1'b1, v=v-1'b1)[*1:$] ##0 v==1'b0 ##0 a==1'b1;
You’re correct, you could have written this as:
(a==1'b1, v=v-1'b1)[*1:$] ##0 v==1'b0 && a==1'b1;
the Boolean_expression && Boolean_expression has a different connotation than the Boolean_expression ##0 Boolean_expression; the && operator has a combinational logic inference, whereas the ##0 has sequential inference (e.g., occurring after). Thus, in this case, I wanted to express that at the end of the count (when v==0) I want to then test that a==1’b1. The point here is that from an intent or emphasis point of view, there is a difference.
Cannot use $stable because the range is not static, it is dynamic, per the requirement:
- SystemVerilog Assertions Handbook 3rd Edition, 2013 ISBN 878-0-9705394-3-6
- A Pragmatic Approach to VMM Adoption 2006 ISBN 0-9705394-9-5
- Using PSL/SUGAR for Formal and Dynamic Verification 2nd Edition, 2004, ISBN 0-9705394-6-0
- Real Chip Design and Verification Using Verilog and VHDL, 2002 isbn 0-9705394-2-8
- Component Design by Example ", 2001 ISBN 0-9705394-0-1
- VHDL Coding Styles and Methodologies, 2nd Edition, 1999 ISBN 0-7923-8474-1
- VHDL Answers to Frequently Asked Questions, 2nd Edition ISBN 0-7923-8115
Thank you Ben and raku for your inputs
In reply to raku:
Hi Raku,
I see that this code is perfectly working fine for ‘x’ cycles but aren’t we taking care of falling edge of ‘a’ ??
I do not think ‘a’ will be high for exactly ‘x’ cycles, how are we checking whether ‘a’ is falling to 0 after ‘x’ cycles i.e after our local counter ‘v’ goes to zero ??
Thanks in advance!
