saritr
August 8, 2016, 3:29pm
1
I have two interface:
interface pakmx_if_in ();
logic clk;
logic rst;
logic [7:0] data_in;
logic data_en;
logic packet_start;
logic packet_err;
logic busy;
endinterface
interface pakmx_if_out ();
logic ch_data_en;
logic ch_start;
logic [7:0] ch_data;
endinterface
I want that thw output interface (pakmx_if_out) will have the same clk and reset as pakmx_if_in.
How can I do it?
In reply to saritr :
You have 2 options:
(1) I presume clk and rst are inputs to both interfaces. Then pass them as arguments to both interfaces:
interface pakmx_if_in (input logic clk, input logic rst);
endinterface
interface pakmx_if_out (input logic clk, input logic rst);
endinterface
clk and reset will be generated in the toplevel module.
(2) You add both signals to the interface description like this:
logic clk;
logic rst;
endinterface
logic clk;
logic rst;
endinterface
All shared signals between interfaces should be made a ports of your interface.
logic data_en;
logic packet_start;
logic packet_err;
logic busy;
endinterface
logic ch_data_en;
logic ch_start;
endinterface
logic clk, rst;
pakmx_if_in if_in(.*)
pakmx_if_out if_out(.*);
If one interface is the source of the clk or reset, then change the
input to
output accordingly.
saritr
August 9, 2016, 7:16am
4
In reply to chr_sue :
You have 2 options:
endinterface
endinterface
logic clk;
logic rst;
endinterface
logic clk;
logic rst;
endinterface
I want to use option 2.
I don’t understand how each of the ckl and rst “know” that it’s the same like the other interface. Where I have to connect them?
You’ll have the instances of both interfaces in the toplevel module.
If you are generating clk and rst in this moule you have to connect them to the interface signals accordingly.
saritr
August 9, 2016, 7:51am
6
Like this:
//Clock generation
initial vif_in.clk = 1’b1;
always #5ns vif_in.clk = ~vif_in.clk;
initial vif_out.clk = 1’b1;
always #5ns vif_out.clk = ~vif_out.clk;
//rst
vif_in.rst = 1’b1;
@(posedge vif_in.clk);
vif_in.rst = 1’b0;
vif_out.rst = 1’b1;
@(posedge vif_out.clk);
vif_out.rst = 1’b0;
Yes something like this. In your case rst is different for both interfaces.
vif_in.rst = 1’b1;
vif_in.rst = 1’b0;
vif_out.rst = 1’b1; // is this a typo?
vif_out.rst = 1’b0;
See my remark above, please.
