Dynamic delay assertion
I want to write an assertion like below pseudo code:
virtual interface user_if vif;
@(posedge clk)
output ##(vif.delay) input;
Now here, my delay is driven from the virtual sequence and keep changing during sim hence, dynamic delay.
What’s the easiest/simplest way to write this?
Thank you in advance.
In reply to chandnidodiya:
Where are you applying the assertion?
If it’s in the interface then you can use my package at
https://verificationacademy.com/forums/systemverilog/sva-package-dynamic-and-range-delays-and-repeats
From the package you need to apply
   sequence dynamic_delay(count);
        int v;
      (count<=0) or ((1, v=count) ##0 (v>0, v=v-1) [*0:$] ##1 v<=0);
    endsequence // dynamic_delay
// in your interface
interface name;
  import sva_delay_repeat_range_pkg::*;
  int delay=2; // can be reassigned as needed later on
  property p;
    int v;
    (1, v=input1) ##0 dynamic_delay(delay) ##0 output1==v;
  ap_dyn_delay: assert property(@(posedge clk) p);
From your code, it seems that you want to do the assertion from the class.
SVA does not support uses in classes, but you have 2 options:
  1. Copy the class variables into the virtual interface that has the SVA as shown above.
    I addressed that in my paper SVA-in-a-UVM-Class-based-Environment
  2. Create a task that at every clock edge initiates a forked task that computes this assertion. Read my paper Understanding the SVA Engine (link to the paper is in my signature).
  3. Papers:
My assertion is in test bench top module.
  input_type input1, output1;  // can be int, bit vector, ....
  property p; // give it a meaningful name
    input_type v;
