why does cover($past(full)); failed but cover(full); passed ?
Besides, did my code miss any of the verification cases/scenario stated in Verification of ASYNCHRONOUS FIFO - UVM - Verification Academy ?
The following code had passed both BMC and induction at depth of 5. The only test failed is cover($past(full)); at line 328 of async_fifo.sv
// Credits to:
// https://github.com/jbush001/NyuziProcessor/blob/master/hardware/fpga/common/async_fifo.sv
// https://github.com/ZipCPU/website/blob/master/examples/afifo.v
// Copyright 2011-2015 Jeff Bush
// Licensed under the Apache License, Version 2.0 (the "License");
// you may not use this file except in compliance with the License.
// You may obtain a copy of the License at
// http://www.apache.org/licenses/LICENSE-2.0
// Unless required by applicable law or agreed to in writing, software
// distributed under the License is distributed on an "AS IS" BASIS,
// WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
// See the License for the specific language governing permissions and
// limitations under the License.
// Asynchronous FIFO, with two clock domains
// reset is asynchronous and is synchronized to each clock domain
// internally.
// NUM_ENTRIES must be a power of two and >= 2
`default_nettype none
module async_fifo
#(parameter WIDTH = 32,
parameter NUM_ENTRIES = 8)
(input write_reset,
input read_reset,
// Read.
input read_clk,
input read_en,
output [WIDTH - 1:0] read_data,
output logic empty,
// Write
input write_clk,
input write_en,
output logic full,
input [WIDTH - 1:0] write_data);
localparam ADDR_WIDTH = $clog2(NUM_ENTRIES);
logic[ADDR_WIDTH - 1:0] write_ptr_sync;
logic[ADDR_WIDTH - 1:0] read_ptr;
logic[ADDR_WIDTH - 1:0] read_ptr_gray;
logic[ADDR_WIDTH - 1:0] read_ptr_nxt;
logic[ADDR_WIDTH - 1:0] read_ptr_gray_nxt;
logic reset_rsync;
logic[ADDR_WIDTH - 1:0] read_ptr_sync;
logic[ADDR_WIDTH - 1:0] write_ptr;
logic[ADDR_WIDTH - 1:0] write_ptr_gray;
logic[ADDR_WIDTH - 1:0] write_ptr_nxt;
logic[ADDR_WIDTH - 1:0] write_ptr_gray_nxt;
logic reset_wsync;
logic [WIDTH - 1:0] fifo_data[0:NUM_ENTRIES - 1];
assign read_ptr_nxt = read_ptr + 1;
assign read_ptr_gray_nxt = read_ptr_nxt ^ (read_ptr_nxt >> 1);
assign write_ptr_nxt = write_ptr + 1;
assign write_ptr_gray_nxt = write_ptr_nxt ^ (write_ptr_nxt >> 1);
// Read clock domain
synchronizer #(.WIDTH(ADDR_WIDTH)) write_ptr_synchronizer(
.clk(read_clk),
.reset(reset_rsync),
.data_o(write_ptr_sync),
.data_i(write_ptr_gray));
assign empty = write_ptr_sync == read_ptr_gray;
/* For further info on reset synchronizer, see
https://www.youtube.com/watch?v=mYSEVdUPvD8 and
http://zipcpu.com/formal/2018/04/12/areset.html */
synchronizer #(.RESET_STATE(1)) read_reset_synchronizer(
.clk(read_clk),
.reset(read_reset),
.data_i(0),
.data_o(reset_rsync));
always_ff @(posedge read_clk, posedge reset_rsync)
if (reset_rsync)
/*AUTORESET*/
// Beginning of autoreset for uninitialized flops
read_ptr <= 0;
read_ptr_gray <= 0;
// End of automatics
else if (read_en && !empty)
read_ptr <= read_ptr_nxt;
read_ptr_gray <= read_ptr_gray_nxt;
assign read_data = fifo_data[read_ptr];
// Write clock domain
synchronizer #(.WIDTH(ADDR_WIDTH)) read_ptr_synchronizer(
.clk(write_clk),
.reset(reset_wsync),
.data_o(read_ptr_sync),
.data_i(read_ptr_gray));
assign full = write_ptr_gray_nxt == read_ptr_sync;
synchronizer #(.RESET_STATE(1)) write_reset_synchronizer(
.clk(write_clk),
.reset(write_reset),
.data_i(0),
.data_o(reset_wsync));
integer i;
always_ff @(posedge write_clk, posedge reset_wsync)
if (reset_wsync)
//`ifdef NEVER
for (i=0; i<NUM_ENTRIES; i++)
fifo_data[i] <= {WIDTH{1'b0}}; // Suppress autoreset
//`endif
/*AUTORESET*/
write_ptr <= 0;
write_ptr_gray <= 0;
else if (write_en && !full)
fifo_data[write_ptr] <= write_data;
write_ptr <= write_ptr_nxt;
write_ptr_gray <= write_ptr_gray_nxt;
/*See https://zipcpu.com/blog/2018/07/06/afifo.html for a formal proof of afifo in general*/
`ifdef FORMAL
reg first_clock_had_passed;
reg first_write_clock_had_passed;
reg first_read_clock_had_passed;
initial first_clock_had_passed = 0;
initial first_write_clock_had_passed = 0;
initial first_read_clock_had_passed = 0;
always_ff @($global_clock)
first_clock_had_passed <= 1;
always_ff @(posedge write_clk)
first_write_clock_had_passed <= 1;
always_ff @(posedge read_clk)
first_read_clock_had_passed <= 1;
//always @($global_clock)
//assert($rose(reset_wsync)==$rose(reset_rsync)); // comment this out for experiment
initial assume(write_reset);
initial assume(read_reset);
initial assert(empty);
initial assert(!full);
if(reset_wsync)
assert(write_ptr == 0);
assert(write_ptr_gray == 0);
assert(!full);
else if(first_write_clock_had_passed)
if(reset_rsync)
assert(read_ptr == 0);
assert(read_ptr_gray == 0);
assert(empty);
else if(first_read_clock_had_passed)
if (first_clock_had_passed)
if(reset_wsync)
assert(!full);
assert(read_data == 0);
else if (!$rose(write_clk))
assume($stable(write_en));
assume($stable(write_data));
assert($stable(full));
if(reset_rsync)
assert(empty);
else if (!$rose(read_clk))
assume($stable(read_en));
assert($stable(empty));
if(!reset_wsync && !$rose(write_clk) && !write_en) assert($stable(read_data));
`endif
/*The following is a fractional clock divider code*/
`ifdef FORMAL
if f_wclk_step and f_rclk_step have different value, how do the code guarantee that it will still generate two different clocks, both with 50% duty cycle ?
This is a fundamental oscillator generation technique.
Imagine a table, indexed from 0 to 2^N-1, filled with a square wave
If you stepped through that table one at a time, and did a lookup, the output would be a square wave
If you stepped through it two at a time--same thing
Indeed, you might imagine the square wave going on for infinity as the table replicates itself time after time, and that the N bits used to index it are only the bottom N--the top bits index which table--but they become irrelevant since we are only looking for a repeating waveform
Hence, no matter how fast you step as long as it is less than 2^(N-1), you'll always get a square wave
http://zipcpu.com/blog/2017/06/02/generating-timing.html
http://zipcpu.com/dsp/2017/07/11/simplest-sinewave-generator.html
http://zipcpu.com/dsp/2017/12/09/nco.html
localparam F_CLKBITS=5;
wire [F_CLKBITS-1:0] f_wclk_step, f_rclk_step;
assign f_wclk_step = $anyconst;
assign f_rclk_step = $anyconst;
always @(*)
assume(f_wclk_step != 0);
always @(*)
assume(f_rclk_step != 0);
always @(*)
assume(f_rclk_step != f_wclk_step); // so that we have two different clock speed
reg [F_CLKBITS-1:0] f_wclk_count, f_rclk_count;
f_wclk_count <= f_wclk_count + f_wclk_step;
f_rclk_count <= f_rclk_count + f_rclk_step;
always @(*)
assume(write_clk == gclk_w);
assume(read_clk == gclk_r);
cover(write_clk);
cover(read_clk);
wire gclk_w, gclk_r;
wire enable_in_w, enable_in_r;
assign enable_in_w = $anyseq;
assign enable_in_r = $anyseq;
clock_gate cg_w (.gclk(gclk_w), .clk(f_wclk_count[F_CLKBITS-1]), .enable_in(enable_in_w));
clock_gate cg_r (.gclk(gclk_r), .clk(f_rclk_count[F_CLKBITS-1]), .enable_in(enable_in_r));
`endif
`ifdef FORMAL
// Some cover statements, to make sure valuable states
// are even reachable
// Make sure a reset is possible in either domain
cover(write_reset);
cover(read_reset);
cover((empty)&&(!$past(empty)));
always @(*)
cover(full);
if (first_write_clock_had_passed)
cover($past(full)&&($past(write_en))&&(full));
cover($past(full)&&(!full));
cover((full)&&(write_en));
cover(write_en);
cover((empty)&&(read_en));
if (first_read_clock_had_passed)
cover($past(!empty)&&($past(read_en))&&(empty));
`endif
`ifdef FORMAL
/* twin-write test */
// write two pieces of different data into the asynchronous fifo
// then read them back from the asynchronous fifo
wire [WIDTH - 1:0] first_data;
wire [WIDTH - 1:0] second_data;
assign first_data = $anyconst;
assign second_data = $anyconst;
reg first_data_is_written;
reg first_data_is_read;
reg second_data_is_written;
reg second_data_is_read;
initial first_data_is_read = 0;
initial second_data_is_read = 0;
initial first_data_is_written = 0;
initial second_data_is_written = 0;
always @(*) assume(first_data != 0);
always @(*) assume(second_data != 0);
always @(*) assume(first_data != second_data);
if(reset_wsync)
first_data_is_written <= 0;
second_data_is_written <= 0;
else if(write_en && !first_data_is_written)
assume(write_data == first_data);
first_data_is_written <= 1;
else if(write_en && !second_data_is_written)
assume(write_data == second_data);
second_data_is_written <= 1;
reg [WIDTH - 1:0] first_data_read_out;
reg [WIDTH - 1:0] second_data_read_out;
initial first_data_read_out = 0;
initial second_data_read_out = 0;
if(reset_rsync)
first_data_read_out <= 0;
first_data_is_read <= 0;
second_data_is_read <= 0;
else if(read_en && first_data_is_written && !first_data_is_read)
first_data_read_out <= read_data;
first_data_is_read <= 1;
else if(read_en && second_data_is_written && !second_data_is_read)
second_data_read_out <= read_data;
second_data_is_read <= 1;
if(first_data_is_read) cover(first_data == first_data_read_out);
if(second_data_is_read) cover(second_data == second_data_read_out);
`endif
