Complicated assertion
As a part of my verification environment I try to check with assertion the following constraint:
“The output remain stable until the next result_valid is rising again (not include the cycle of rising result_valid)”
My property is:
property RESULT_STABILITY(signal);
@(posedge clk) disable iff (~resetn)
($rose(result_valid)) |-> stable(signal)[*1:] ##0 ($rose(result_valid));
endproperty: RESULT_STABILITY
This property is wrong because the output signal is changing in same cycle the result_valid is rising, and hence the property is not compatible with the end of the constraint
My guess is that the right solution somehow involve the $past function, but I don’t know how.
Any help?
In reply to akivama:
Follow the waveform
Google Photos
sigtype v;
    ##1 (1,v=sig) ##1 v==sig[*0:$] ##1 ($rose(result_valid));
Hi Ben,
Thank you for your quick response.
I have some questions about your solution:
sigtype v;
(rose(result_valid)) |-> ##1 **(1,v=sig)** ##1 v==sig[*0:] ##1 ($rose(result_valid));
  1. What sigtype means?
  2. What (1,v=sig) means?
1800 defines one of options for a sequence as:
sequence_expr ::=
| (sequence_expr {, sequence_match_item}) [sequence_abbrev]
For example:
property p;
  int v;
     (a            , v=data)                     [*2] |-> ##1 sig==data;
// (sequence_expr {, sequence_match_item}) [sequence_abbrev]
// for your example:
bit[15:0] sig;
property p;
  bit[15:0] v;  // same type as the type for sig
// The "1" in (1, v=sig) is the sequence_expr, alwasy true to set the local variable
  3. Papers:
($rose(result_valid)) |=>  $stable(sig) until $rose(result_valid);
https://www.linkedin.com/in/patel-rahulkumar/
