Hi All,
If i use function to be the sequence expr, is it legal?
like this
@rose(a) → B(x,y) ##1 c, where B is a function or task. a,c are signal.
I want to check signal c after B returns 1
Thank you
In reply to peter:
There are some caveats in using functions as an expression:
- If the function has a return then you can use it
function int B(bit m, n); return m && n; endfunction
ap_p1: assert property(@(posedge clk) $rose(a) |-> B(x,y) ##1 c); // OK
ap_p2: assert property(@(posedge clk) $rose(a) |-> d==B(x,y) ##1 c); // OK
- Function with return type of void cannot be used in/as an expression.
- tasks cannot be used as an expression.
- Void functions and tasks can be used in a sequence_match_item
- You should avoid using tasks in an assertion, particularly if the task is time consuming
function void inc_sop(bit c);
sop_count=sop_count+1;
endfunction: inc_sop
// ERROR: Function with return type of void cannot be used in/as an expression.
ap_ERROR: assert property(1 |-> inc_sop(sop));
// OK
ap_OK: assert property(1 |-> (1, inc_sop(sop)) );
task automatic inc2_sop(bit c);
endtask: inc2_sop
ap_OK2: assert property(w |-> (e,inc_sop(sop)));
- SVA Package: Dynamic and range delays and repeats SVA: Package for dynamic and range delays and repeats | Verification Academy
- Free books:
- Component Design by Example FREE BOOK: Component Design by Example … A Step-by-Step Process Using VHDL with UART as Vehicle | Verification Academy
- Real Chip Design and Verification Using Verilog and VHDL($3) https://rb.gy/cwy7nb
- A Pragmatic Approach to VMM Adoption
http://SystemVerilog.us/vf/VMM/VMM_pdf_release070506.zip
http://SystemVerilog.us/vf/VMM/VMM_code_release_071806.tar
- Papers:
Understanding the SVA Engine,
Verification Horizons - July 2020 | Verification Academy
Reflections on Users’ Experiences with SVA, part 1
Reflections on Users’ Experiences with SVA | Verification Horizons - March 2022 | Verification Academy
Reflections on Users’ Experiences with SVA, part 2
Reflections on Users’ Experiences with SVA, Part II | Verification Horizons - July 2022 | Verification Academy
SUPPORT LOGIC AND THE ALWAYS PROPERTY
http://systemverilog.us/vf/support_logic_always.pdf
SVA Alternative for Complex Assertions
Verification Horizons - March 2018 Issue | Verification Academy
SVA in a UVM Class-based Environment
SVA for statistical analysis of a weighted work-conserving prioritized round-robin arbiter.
https://verificationacademy.com/forums/coverage/sva-statistical-analysis-weighted-work-conserving-prioritized-round-robin-arbiter.
Hi Ben, you mentioned that avoid using tasks in an assertion, particularly if the task is time consuming.What is the reason?
I have a task A() .Signal x will be driven in A(). When X is driven to be one, signal c should be 1 too.
assert property(@(posedge clk) rose(a) |-> (1,A()) ##[1:] ($rose(x)&c));
Is it ok to do that?
Thank you
In reply to peter:
- Assertions express requirements. Using tasks may make the assertion complex.
- Using a task for support logic (see my paper on that topic in my signature), then it is ok.
- In https://verificationacademy.com/forums/systemverilog/correct-property-count-event-until-another-event-happens.
I used a task because events, used as expressions, is illegal. - My paper on Understanding teh Verification Engine (link in my signature) uses tasks to model assertions.
NOT recommneded. Here
task automatic A();
x<=a_value;
assert property(@(posedge clk) $rose(a) |-> (1,A()) ##[1:$] ($rose(x)&c));
- The assertion is used as a generator and a driver.
- An assertion should be used to verify the properties of the design, and not as a generator.
- Errors may be created. Example:
At t10 a rose(a) causes A() to change x at t40. // thread1
At t20 a rose(a) causes A() to change x at t30. // thread2
Thread1 does not see the x intended to change at t40 because thread2 made x change at t30.
Again, mixing test vector generation inside the verification model is not a good practice.
It’s hog-wash.
