$assertoff scope for specific immediate assertion
Hello.
In order to turn off an immediate assertion, I need to specify its full path.
i.e: $assertoff (test.a_sc.ASRT)
Is there a way not to specify the full path?
i.e: $assertoff (ASRT) [this method does not work].
If not, is the only way is to wrap the assertion with ‘if’ statement, when I want to disable it?
Snapshot of current code:
module test;
bit a;
always begin : a_sc
ASRT: assert (a)
else $assertoff (test.a_sc.ASRT);
Beeri
Below is an application from my SVA book; it explains the use of the #assertoff.
module my_control ();
  initial begin : disable_assertions_during_reset
    $display ("%0t %m Disabling assertions during init..", $time);
    $assertoff (0, top_tb.cpu_rtl_1);
    @ (top_tb.reset_n === 1'b1);
    $display ("%0t %m Enabling assertions after init..", $time);
    $asserton (0, top_tb.cpu_rtl_1);
endmodule : my_control
module top_tb;
  logic clk =1’b0, reset_n = 1’b0;
  bus_if b_if;
  cpu_rtl cpu_rtl_1(clk, reset_n, .*); // Instantiation of cpu module
  my_control my_control_1(); // instantiation of assertion control
endmodule : top_tb
Figure 4.1.4.1.5 Application of the $asserton / $assertoff in a Testbench
Ben Cohen http://www.systemverilog.us/
  • SystemVerilog Assertions Handbook, 3rd Edition, 2013
  • A Pragmatic Approach to VMM Adoption
  • Using PSL/SUGAR … 2nd Edition
  • Real Chip Design and Verification
  • Cmpt Design by Example
  • VHDL books
Ben,
Thank you, but you are using full hierarchy path in your example.
My question was if it is possible not to use full path.
Any idea?
Beeri
In reply to Beeri:
Yes, use the $asserton and $assertoff without any arguments, as shown below.
Simulation produced the following results:
run 100ns
0 top_tb.my_control_1.disable_assertions_during_reset Disabling assertions during init..
55 top_tb.my_control_1.disable_assertions_during_reset Enabling assertions after init..
FAIL RTL at t- 55, a==0
FAIL RTL at t- 65, a==0
FAIL RTL at t- 75, a==0
FAIL RTL at t- 85, a==0
PASS RTL at t- 95, a==1
module my_control (input bit clk, a, b);
    //$assertoff (0, top_tb.cpu_rtl_1);
    $assertoff;
    @ (top_tb.reset_n ==1'b1);
    //$asserton (0, top_tb.cpu_rtl_1);
    $asserton;
   always_comb  ap_0: assert property (@(posedge clk) a) else $display("fail, my control a==%b", $sampled(a));
module cpu_rtl(input bit clk, a, b);
	 ap_0rtl: assert property (@(posedge clk) a)
	 	$display("PASS RTL at t-%t, a==%b", $time, $sampled(a));
	    else $display("FAIL RTL at t-%t, a==%b", $time, $sampled(a));
module top_tb;
	bit clk=1'b0, reset_n=1'b0, a=1, b=0;
  initial forever #5 clk=!clk;
  //bus_if b_if;
 cpu_rtl cpu_rtl_1(clk, a, b); // Instantiation of cpu module
 my_control my_control_1(clk, a, b); // instantiation of assertion control
  always
       repeat(3) @(posedge clk);
       a <=1'b0;
       reset_n<=1'b1;
       a <=1'b1;
       a <=1'b0;
endmodule : top_tb
You can also use the
$assertcontrol(OFF);
$assertcontrol(ON);
This is 1800’2012, and some tools support it.
	// Assertion controls
    let LOCK 	= 1;  // assertion control type
    let UNLOCK 	= 2; 	// assertion control type
    let ON 	= 3;	// assertion control type
    let OFF 	= 4;	// assertion control type
    let KILL 	= 5;	// assertion control type
    let PASSON 	= 6; 	// assertion control type
    let PASSOFF 	= 7; 	// assertion control type
    let FAILON 	= 8; 	// assertion control type
    let FAILOFF 	= 9;	// assertion control type
    let NONVACUOUSON = 10;	// assertion control type
    let VACUOUSOFF 	= 11; // assertion control type
    // $assertoff;
    $assertcontrol(OFF); // using default values of all other arguments
    //$asserton;
    $assertcontrol(ON);
  • SystemVerilog Assertions Handbook 3rd Edition, 2013 ISBN 878-0-9705394-3-6
Thank you Ben,
I’ll try to be more specific:
Please consider the following example:
I am trying to disable ‘CHK_ASRT’ only, not ‘CHK_ASRT2’.
Here it disable both.
Any solution without full path?
Beeri
module test ();
shortint unsigned err_cnt;
  initial begin : bg
      repeat (10) begin
        CHK_ASRT:
        assert ('0)
        else begin
          err_cnt++;
          $error ("Found error #1");
          //I only want to disable this checker
          if (err_cnt == 2) $assertoff ; //But this also disables 'CHK_ASRT2'.
        #1;
      repeat (10) begin
        CHK_ASRT_2:
        assert ('0)
          $error ("Found error #2");
        //This checker should not be disabled, but the '$assertoff' disabled also this one
        #1;
    join
    $finish;
endmodule : test
In reply to Beeri:
You could use an “if” statement as shown below.
module test ();
 bit a_en;
  initial begin : bg
    a_en=1'b1;
      repeat (10) begin
        if(a_en) CHK_ASRT:  assert ('0)
        else begin
          err_cnt++;
          if (err_cnt == 2) a_en=1'b0; // $assertoff ; //But this also disables 'CHK_ASRT2'.
        #1;
      repeat (10) begin
        CHK_ASRT_2:
        assert ('0)
        #1;
    join
    $finish;
endmodule : test
