Assertion to check signal is toggling or not
Assertion to check signal c is stable if b is true otherwise c is the running clock. Frequency of c and assertion clock “clk” is same so cannot use “$changed” to check c is toggling or not as sampled value of c remains same at each posedge of clk. Is there any construct/logic to check c is toggling as something like “always” is used to check stability without dependency on assertion clk?
property p;
@(posedge Clk)
$rose(a) |-> if (b)
always(c)
$changed(c);
Thanks in advance.
In reply to rohithgm:
I don’t fully understand your requirements. However, I have a suggestion that can get you started on the right path. That suggestion makes use of concepts explained in my paper
SVA Alternative for Complex Assertions The paper was published at Verification Horizons - March 2018 Issue | Verification Academy
Your solution would look something like
$rose(a) |-> (1, my_task(b, c));
task automatic my_task(bit b, c);
  // here you can use # delays, wait statements, @ (posedge clk),
  // fork other tasks, or whatever you need to verify your requirements
  1. Verification Horizons - March 2018 Issue | Verification Academy
  2. SVA: Package for dynamic and range delays and repeats | Verification Academy
FREE BOOK: Component Design by Example
… A Step-by-Step Process Using VHDL with UART as Vehicle
Basically, How can I check toggling of signal “c” when frequency of signal “c” is same as “clk”?
“$changed” will get same sampled value of c at each posedge of clk even though “c” is toggling.
$changed assertion will fail if “c” is toggling with same frequency of clk or remains stable, hence does not matter.
So, cannot use $changed.
One approach for solution would be as follows
property p;
logic v,o;
@(posedge clk)
(a > 2, v = c) |-> if (b)
(@(negedge clk) (1, o = c) |-> (v == o)) // not sure why always(c) is not working
(@(negedge clk) (1, o = c) |-> ( v != o));
But above solution assumes both “c” and “clk” have same frequency but not valid if signal “c” is having different frequency than clk. Is there any logic/construct that checks just toggling of signal without dependency on assertion clock.
Looks to me that you are trying to check a gated clock (c) that is synchronous to a master clock (clk). Below is a code with a testbench. Two key approachesL
// Uses the concept of multiclocking where @ (posedge clk)  (a, t=$realtime) you save the current time. Then, with the |> if  @ (posedge c) exactly occurs with the @ (posedge clk)  then the consequent starts right away, thus in synchronism.  Else, it waits till the next @ (posedge c).
 property p_c;
        realtime t;
        @ (posedge clk)  (a, t=$realtime) |-> @ (posedge c) ($realtime==t);
    ap_c: assert property(p_c);
The Other approach uses a task that fires two threads (forks) and each measure the current time, and when joined, check the time diff. The while(a) keep on firing those threads.
   ap_ac: assert property(@ (posedge clk)  $rose(a) |-> (1, t_check()) ); // ** LINE 22
    task automatic t_check();
        automatic realtime ta1, tc;
        $display("%t start of task ", $realtime);
        while (a) begin : while1
                begin : chk1
                    @ (clk);
                    ta1=$realtime;
                    -> e1;
                end : chk1
                begin : chk2
                    @(c);
                    tc=$realtime;
                    -> e2;
                end : chk2
            join
            a_intask: assert(ta1==tc) else $display ("%t clk and c not in sync", $realtime);
            $display("%t ta1= %t tc=%t", $realtime, ta1, tc);
            if(ta1!=tc) -> ec;
        end : while1
// ****** simulation results
                  310 start of task
#                  410 ta1=                  410 tc=                 410
# ** Error: Assertion error.
#    Time: 54 ns Started: 51 ns  Scope: top.ap_c File: C:/ben_play/./a_syncs.sv Line: 22 Expr: $realtime()==t
#    Local vars : t = 51
#                  540 clk and c not in sync
#                  540 ta1=                  510 tc=                 540
#                  640 clk and c not in sync
#                  640 ta1=                  610 tc=                 640
#                  710 ta1=                  710 tc=                 710
#                  810 ta1=                  810 tc=                 810
#                 1110 start of task
#    Time: 114 ns Started: 111 ns  Scope: top.ap_c File: C:/ben_play/./a_syncs.sv Line: 22 Expr: $realtime()==t
#    Local vars : t = 111
#                 1210 clk and c not in sync
#                 1210 ta1=                 1210 tc=                1140
#                 1310 clk and c not in sync
#                 1310 ta1=                 1310 tc=                1240
testbench
    timeunit 1ns;     timeprecision 100ps;
    bit clk0, clk, a, c;
    bit va, vb, vc;
    realtime period =20ns;
    event ec, e1, e2;
    default clocking @(posedge clk);
    endclocking
    initial forever #(period/2) clk0=!clk0;
    always @(clk0) begin
        #1 clk <= clk0;
        if(vb) #3 c <= clk0;
        else c <= clk0;
    property p_c;
        realtime t;
    //  How can I check toggling of signal "c" when
    //  frequency of signal "c" is same as "clk"?
                begin : chk1
                    @ (clk);
                    ta1=$realtime;
                    -> e1;
                end : chk1
                begin : chk2
                    @(c);
                    tc=$realtime;
                    -> e2;
                end : chk2
            join
            if(ta1!=tc) -> ec;
        end : while1
        repeat(200) begin
            @(posedge clk0);
            if (!randomize(va, vb, vc)  with
            { va dist {1'b1:=10, 1'b0:=1};
            vb dist {1'b1:=1, 1'b0:=2};
            vc dist {1'b1:=1, 1'b0:=1};
        #3;
        a <= va;
        $stop;
    http://systemverilog.us/cmpts_free.pdf
Ben,
I have a scenario wherein I need to check whether the clock sys_clk toggles within 80 clock cycles of en going low. I have a reference clock named refclk to time the assertion. The assertion should fail if the clock sys_clk does not toggle within the specified time.
I tried your solution but it does not fail when sys_clk is not toggling. Because the fork waits for posedge of the clock and never fails.
In reply to nimitz_class:
Show your code
Try this code.
    bit clk0, clk, a, c, refclk, sysclk, window;
    bit va, vb, vc;
    event ec, e1, e2;
    realtime ta1, tc, done, active;
    int count;
    endclocking
        repeat(90) @(posedge refclk);
        forever @(posedge refclk) sysclk=!sysclk;
        window=1'b1;
        repeat(120) @(posedge refclk);
        window=1'b0;
    initial forever #(period/2) refclk=!refclk;
        #1 clk <= clk0;
        else c <= clk0;
    property p_c;
        realtime t;
    /*I need to check whether the clock sys_clk toggles within 80 clock cycles of en going low.
Because the fork waits for posedge of the clock and never fails.*/
    initial t_check();
        automatic realtime ta1, tc, done, active;
        int count;
        while (window) begin : while1
                begin : chk1
                    //@ (refclk);
                    count = count+1'b1;
                    if(count>= 80) done=1'b1;
                    -> e1;
                end : chk1
                begin : chk2
                    @(posedge sysclk);
                   active=1'b1;
                    -> e2;
                end : chk2
            join_none
            a_intask: assert(!done || active) else $display ("%t sysclk is not active ", $realtime);
            if(active) -> ec;
            active=1'b0;
            @ (refclk);
        end : while1
    /*initial begin
        repeat(200) begin
            @(posedge clk0);
        #3;
        a <= va;
        $stop;
    end */
Will this not work if I just want to check clk gating during assertion of en?
 assert((sys_clk|~en) == 0)
 $error("error:")
In reply to rlot:
$error("error:")
sys_clk is a clock that toggles between 1 and 0. Thus, if en==1 the assertion fails when sys_clk goes to 0.
Hi ,
What are the different ways to check clock is toggling or not when reset is enabled (other than assertions)?
Hi @user49 @samirxd @Kishankk @rohithgm
It might be easy question
Can you please explain what here always() means also changed()
One more thing
Here what is use of 1. Can you explain please.
