Writing a sequence within a sequence
I have two sequences as follows:
sequence seq_busy;
    1[*0:$] ##1 $rose(busy) ##[1:$] $fell(busy);
endsequence
sequence seq_valid;
    $rose(valid) ##[1:$] $fell(valid);
endsequence
assert property (
    @(posedge clk)
    seq_valid[*1] within seq_busy
Basically, I expect valid to go high and low (once) within the duration of busy signal going high. I manually tested this assertion by a very simple testbench but this assertion is not doing what i thought it would be doing.
busy |-------------|__
valid |-------|___
The above diagram causes this assertion to pass but the following don’t
valid______|-----------------
valid______|—|_|–|_____
I think there is something silly i’m missing here. Any help will be appreciated.
In reply to ak180:
It would help to create a complete example that we can try, and explain what the second two diagrams do that you think they should not be doing.
In reply to ak180:
Changed your code.
module m;
    `include "uvm_macros.svh"   import uvm_pkg::*;
    bit clk, busy, valid;
    /* busy ___|-------------|_____
       valid _____|-------|________ */
    /* sequence seq_busy;
    endsequence
    sequence seq_valid;
    endsequence */
    ap_busy_valid: assert property (@(posedge clk)
         $rose(busy)  |-> ##1  // is ##1 Needed?? Depends on requirements
           $rose(valid)[->1] ##1 $fell(valid)[->1] intersect  $fell(busy)[=1] );
            repeat (90) begin
              @(posedge clk); #2;
              if (!randomize(busy, valid) with {
               busy  dist {1'b1 := 8, 1'b0 := 1};
               valid dist {1'b1 := 1, 1'b0 := 1};
              }) `uvm_error("MYERR", "This is a randomize error");
            $finish;
  3. Papers:
In reply to ak180:
I think the code is doing exactly what it is intended to do. The 2nd and 3rd scenarios are fail case.
