Write an assertion for checking whether global clock is working properly with out taking a relative clock
I have been trying to write an assertion for checking whether global clock is working perfectly.
I formulated an idea using a relative clock. How to do it with out the relative clock?
I drop my code with relative clock so that you can get the idea correctly
// gclk is the global clock
// clk is the reference clock
// Assertion for the problem
  property GCLK;
    @(posedge clk) $rose(gclk) @negedge(clk) $fell(gclk);
  endproperty : GCLK
In reply to bachan21:
Not clear as to what you mean by checking whether global clock is working properly.
If you mean that checking that it is toggling per required frequency, you can do something like the following:
    timeunit 1ns/10ps;
     bit g_clk, clk, a, b;
     global clocking clk_global @(posedge g_clk); endclocking
     default clocking cb_clk @ (posedge clk);  endclocking
     let half_period=5ns;
     initial forever #half_period g_clk=!g_clk;
     always  @(posedge g_clk)  begin
        clk <= ! clk; // derived clk
    initial begin : b0
      bit got_gclk, done;
       begin  : f_ever
          begin : one
            @(g_clk);
            got_gclk=1'b1;
            done=1'b1;
          end  : one
          begin : two
            #(half_period+1);
            done=1'b1;
          end : two
        join_none
        wait(done);
        a_gclk: assert(got_gclk); // g_clk is active
        got_gclk=1'b0;
        done=1'b0;
      end : f_ever
    end  : b0
       #100;
       $finish;
Note: assertion: A statement that a given property is required to hold. An assertion is a “statement about a design’s intended behavior” (From Assertion-Based Design, Foster).
It can be written in many forms, SVA is one of them, but there are other approaches.
  1. SVA Package: Dynamic and range delays and repeats https://rb.gy/a89jlh
  3. Papers:
Thanks for the reply Ben.
I understood your approach.
But my intention is to use SVA to solve this problem.
I will clarify the scenario for you.
I have a clock (Lets call it global clock and take a time period of 10ns).
I want to write an assertion such that it will check clock is maintaining that 10ns time period
My previous assertion checks for activity.
For measurements see examples
https://verificationacademy.com/forums/systemverilog/checking-clock-period-using-system-verilog-assertion
Use realtime and $realtime
