Working of bind construct
From assertion perspective ::
’ bind ’ allows us to keep design logic separate from the assertion logic . Designers do not like to see anything in RTL that isn’t going to be synthesized . ’ bind ’ helps in that direction
Consider following code ::
module  designmodule  ( da , db , dclk );
  input   da , dclk ;
  output  logic  db;
  always @( posedge dclk )  db <= da;
module  propertymodule ( pa , pb , pclk );
  input  pa , pb , pclk ;
  property  rc1;
    pa |=> pb ;
  baseP:assert  property ( @( posedge pclk )  rc1 )  else  $display($time , " property  fails ");
[Q1] What’s the difference between following 2 Scenarios ::
//  Scenario1  ::  Using  bind
module  tb1;
 bind  designmodule  propertymodule  dpM ( .pa( da ) , .pb( db ) , .pclk( dclk ) );
//  Scenario2  ::  Without  bind
module  tb2;
 logic  ta , tb , tclk;
 designmodule  DM  ( .da(ta) , .db( tb ) , .dclk( tclk ) ) ;
 propertymodule  PM ( .pa( ta ) , .pb( tb ) , .pclk( tclk ) );
One possible answer is Scenario2 applies to only specific instance of designmodule whereas with Scenatio1 applies to every instances of designmodule .
[Q2] Are there any further differences between the two ?
 **Significance  of  instance  created  by  ' bind '  construct  ::**
  Within  Scenatio1 ,  an  instance  of  propertymodule  named  ' dpM '  is  created  by  default  within  every  instance  of  designmodule .
  By  default  in  Verilog  a  module  declaration  in  itself  doesn't  do  anything ( unless it's top_tb ) , one  needs  to  instantiate  it  for  the  logic  defined  within  it  to  work .
  Hence  simply  declaring  propertymodule  doesn't  do  anything , one  needs  to  create  an  instance  of  propertymodule  for  the  assertions to  execute .
  bind  construct  creates  the  instance  of  propertymodule  for  the  assertions  to  trigger .
  This  explains  the  significance  of  instance  name  created  by  bind  construct  for  assertion  based  logic .
  **[Q3] For  non-assertion  based  module / interface  what's  the  significance  of  the  instance  name  ?**
In reply to Have_A_Doubt:
  1. The bind is a better approach because your verification module can easily access signals that are internal to the design. When you bind, you are like instantiating the VF module inside the design module.
  2. Use the SVG module interface syntax instead of the Verilog approach; it is more readable.
  3. Use the same variable name throughout. Your da, pa stuff is confusing, particularly whne debugging. It will drive you crazy to continually convert one for the other.
module  designmodule  (input bit da, dclk, output bit db);
  bit a, b; // used internally in the desing and are not IO
  int count;
  always @( posedge dclk) if(da) count <= count+1;
module  propertymodule ( input bit da , db , dclk, a, b, int count);
  property  rc1;
    da |=> db ;
  baseP:assert  property ( @( posedge dclk )  rc1 );
ap_Count: assert property(@(posedge dclk) da |-> ##1 count==$past(count) +1);
module  tb1;
  ( .da(da), .db(db),.dclk(dclk), .a(a), .b(b), .count(count));
  2. Free books:
  1. Papers:
    Understanding the SVA Engine,
    Verification Horizons
    Reflections on Users’ Experiences with SVA, part 1
    Reflections on Users’ Experiences with SVA, part 2
    Reflections on Users’ Experiences with SVA - Part II
    Understanding and Using Immediate Assertions
    SUPPORT LOGIC AND THE ALWAYS PROPERTY
    http://systemverilog.us/vf/support_logic_always.pdf
    SVA Alternative for Complex Assertions
    SVA in a UVM Class-based Environment
    SVA for statistical analysis of a weighted work-conserving prioritized round-robin arbiter.
    https://verificationacademy.com/forums/coverage/sva-statistical-analysis-weighted-work-conserving-prioritized-round-robin-arbiter.
    https://www.udemy.com/course/sv-pre-uvm/splay($time , " property fails ");
