Dear friend,
I have 2 question regarding to the Synthesis.
First,
Can anyone specify that which SystemVerilog syntax can be synthesized?
As an example, I want to know that the following line can be synthesized?
parameter g = 7'b5;
Second,
What is the difference between the parameter and reg from the synthesis point of view? While both store a value. Register can be modified but parameter is constant. Is there anything else?
Parameter cannot be synthesized. It is just another way of representation. In your example, to make the value 7’b5 easier to read in the code, then it can be represented in another way by using a parameter called g… It is used for easier coding purposes.
In reply to Mahdiyar:
This is really not the right forum for discussing synthesis. You should check with the vendor of your tool, they probably have documentation on what SystemVerilog they support. In a perfect world, every SystemVerilog construct could be synthesizable, but most tools have a common subset.
Parameters are like constants, but they can be overridden on an instance basis. You need to look for some basic Verilog training on parameters. In SystemVerilog, parameters can also be types as well as values. I’m not sure all synthesis tools support that yet.
SystemVerilog replaces the keyword reg with logic. Not everything declared as a reg in Verilog becomes a Register.
