I have a set_config() function in my test class in which I set values for these variables. The values are passed from the command line(VCS) via plusargs as :
My issue is that, whatever combination of configs I pass from command line, the first values in typedef declaration are the values for handles that always get set, i.e. when I display the cfg variables, they’d always be:
end_type = EOT
data_type = RANDOM
mode = FAST
I am not able to understand where I am going wrong in this.
If there is some other way of doing this, please do let me know.
Thanks for helping out but i’m afraid the behavior is still the same. Can you tell me why/how is this happening in the first place? I haven’t put any default case or anything in my code.
A small workaround using static casting can be done to fulfill your requirement. Please find the below example. Please look at the way in which typedef enums are declared and how $value$plusargs and static casting is used. Instead of supplying string through the command line, I am supplying integer values. The command-line options can be like “+end_type=1 +data_type=2 +mode=0”. With this workaround, I am getting your expected output.
// Example compiled by Putta Satish
// Command line options can be as shown below.
// +end_type=1 +data_type=2 +mode=0
`include "uvm_macros.svh"
import uvm_pkg::*;
typedef enum { EOT=0, DELAY=1} end_type;
typedef enum { RANDOM=0, INCR=1, LOAD=2} data_type;
typedef enum { FAST=0, SLOW=1} mode;
class config_db extends uvm_object;
end_type e_t;
data_type d_t;
mode m_e;
function new(string name = "config_db");
super.new(name);
class drv extends uvm_driver #(uvm_sequence_item);
config_db cfg_h;
function new(string name = "drv", uvm_component parent = null);
super.new(name, parent);
if(!uvm_config_db#(config_db)::get(this, "", "STR", cfg_h))
`uvm_fatal(get_type_name,"getting failed");
phase.raise_objection(this);
$display("end_type = %s", cfg_h.e_t);
$display("data_type = %s", cfg_h.d_t);
$display("mode = %s", cfg_h.m_e);
#1;
$display("Current simulation time is %t", $time);
phase.drop_objection(this);
config_db cfg_h_top;
int end_i, data_i, mode_i;
drv drv_h;
initial
drv_h = new("drv_h");
if ($value$plusargs("end_type=%d", end_i))
$display("got the end_type value");
if ($value$plusargs("data_type=%d", data_i))
$display("got the data_type value");
if ($value$plusargs("mode=%d", mode_i))
$display("got the mode value");
cfg_h_top = new("cfg_h_top");
cfg_h_top.e_t = end_type'(end_i);
cfg_h_top.d_t = data_type'(data_i);
cfg_h_top.m_e = mode'(mode_i);
uvm_config_db#(config_db)::set(null, "", "STR", cfg_h_top);
run_test();
