Hi all,
case(val)
[32'h5:32'h18] : $display("In range");
default: $dsiplay("DEFAULT");
endcase
How can we use range operator inside case statement.
Thank you,
mpurna.
Hi all,
case(val)
endcase
Thank you,
mpurna.
Hi all,
I got it. We need to use the inside operator along with case statement.
case(val) inside
endcase
Thank you,
mpurna.
In reply to mpurna:
Is this synthesizeable?
*In reply to rparab:*The
$display statement is not synthesizable. Otherwise, the
case inside statement should be synthesizable if your tool supports. it.
I am using inside with a case statement.
For example
logic [3:0] xyz
unique case (xyz) inside
[0:1] : a = 4’d10;
[2:5] : a = 4’d11;
[6:15]: a = 4’d2;
endcase
Two tools gives warnings/error in this case:
I know it all depends on how these tools interpret it, but, I hope DC doesnt screw it up and interprets it correctly.
Regards,
Rupesh
In reply to mpurna:
Is it possible to write multiple range which are non contiguous in a single thread. if possible how?
Thanks & Regards,
Saumya
In reply to saumyaj:
In reply to mpurna:
Thanks & Regards,
Saumyaj
task disp();
case(val) inside
[32'h0:32'h5],[32'h10:32'h20] : $display("RANGE1,RANGE3");
[32'h6:32'h8] : $display("RANGE2");
default: $display("DEFAULT");
endcase
In reply to Rahulkumar:
Thanks Rahulkumar:)
