Is there an OVL assertion to find out if the rise of a signal to the next rise of a signal duration is between 2 time values? The example I want to check that the rise of signal A to the next rise of signal A is between 100ns +/- 5ns.
In reply to VerifEx:
Check out the following link and modify it appropriately
https://verificationacademy.com/forums/systemverilog/checking-clock-period-using-system-verilog-assertion
Once the signal gets asserted, I capture the current time, then I want to wait until the signal falls and make sure the delta time is between my min and max time. How do you do that comparison when it de-asserts?
property measure_rise_to_fall(bit clk, bit reset, bit sig_a, bit sig_b, time min_time, time max_time);
time current_time;
@(posedge clk) disable iff (reset) (($rose(sig_a),current_time=$realtime()) |=> $fell(sig_b) |=> ((min_time > ($realtime()-current_time)) & (max_time < ($realtime() - current_time))));
endproperty : measure_rise_to_fall
In your requirements, I read the following:
Once the signal “a” gets asserted (i…e, $rose(a)), I capture the current time, then I want to wait until the signal**“b” falls (i.e., @(negedge b)**, which can be multiple clock periods (or less) of the @(posedge clk)) and make sure the delta time is between my min and max time. How do you do that comparison when it de-asserts?
Below are 2 solutions:
- Solution using a task. Read my paper
PAPER: Understanding the SVA Engine + Simple alternate solutions - SystemVerilog - Verification Academy
Abstract: Understanding the engine behind SVA provides not only a better appreciation and limitations of SVA, but in some situations provide features that cannot be simply implemented with the current definition of SVA. This paper first explains, by example, how a relatively simple assertion example can be written without SVA with the use of SystemVerilog tasks; this provides the basis for understanding the concepts of multithreading and exit of threads upon a condition, such as an error in the assertion. The paper then provides examples that uses computational variables within threads; those variables can cause, in some cases, errors in SVA. The strictly emulation model with tasks solves this issue. - An assertion of same
http://SystemVerilog.sv/fv/time_between.sv
// Once the signal gets asserted, I capture the current time, then I want to wait until the signal falls
// and make sure the delta time is between my min and max time.
//How do you do that comparison when it de-asserts?
bit clk, a, b, c, rst;
initial forever #10 clk=!clk;
task automatic t_halffclk();
automatic realtime t_then;
if($rose(a)) begin
t_then = $realtime;
// @(posedge clk)
@(negedge b) a_time: assert(($realtime-t_then > 32ns) &&
($realtime-t_then < 43ns) )
$display("OK, negedge b =%t, delta=%t", $realtime, $realtime-t_then); else
$display("error, negedge b=%t, delta=%t", $realtime, $realtime-t_then);
else return;
always @(posedge clk) begin
t_halffclk();
property measure_rise_to_fall(bit clk, bit reset, bit sig_a, bit sig_b, realtime min_time, realtime max_time);
time current_time;
($rose(sig_a),current_time=$realtime)
|=> @(negedge b) ($realtime-current_time > min_time) && ($realtime-current_time < max_time);
ap_measure_rise_to_fall: assert property(measure_rise_to_fall( clk, rst, a, b, 32, 43));
repeat(200) begin
@(posedge clk);
if (!randomize(a, c) with
{ a dist {1'b1:=1, 1'b0:=3};
c dist {1'b1:=1, 1'b0:=1};
if(c) #2 b=c;
else b=c;
$stop;
// simulation results
OK, negedge b = 90, delta= 40
# OK, negedge b = 230, delta= 40
# error, negedge b= 370, delta= 100
# ** Error: Assertion error.
# Time: 370 ns Started: 270 ns Scope: top.ap_measure_rise_to_fall File: time_between.sv Line: 33 Expr: $realtime()-current_time<43
# Local vars : current_time = 270
# Time: 370 ns Started: 350 ns Scope: top.ap_measure_rise_to_fall File: time_between.sv Line: 33 Expr: $realtime()-current_time>32
# Local vars : current_time = 350
# OK, negedge b = 490, delta= 40
# error, negedge b= 710, delta= 80
# Time: 710 ns Started: 630 ns Scope: top.ap_measure_rise_to_fall File: time_between.sv Line: 33 Expr: $realtime()-current_time<43
# Local vars : current_time = 630
# error, negedge b= 870, delta= 60
# Time: 870 ns Started: 810 ns Scope: top.ap_measure_rise_to_fall File: time_between.sv Line: 33 Expr: $realtime()-current_time<43
# Local vars : current_time = 810
# Time: 950 ns Started: 870 ns Scope: top.ap_measure_rise_to_fall File: time_between.sv Line: 33 Expr: $realtime()-current_time<43
# Local vars : current_time = 870
- SVA Handbook 4th Edition, 2016 ISBN 978-1518681448
- A Pragmatic Approach to VMM Adoption 2006 ISBN 0-9705394-9-5
- Using PSL/SUGAR for Formal and Dynamic Verification 2nd Edition, 2004, ISBN 0-9705394-6-0
- Real Chip Design and Verification Using Verilog and VHDL, 2002 isbn 978-1539769712
- Component Design by Example ", 2001 ISBN 0-9705394-0-1
- VHDL Coding Styles and Methodologies, 2nd Edition, 1999 ISBN 0-7923-8474-1
- VHDL Answers to Frequently Asked Questions, 2nd Edition ISBN 0-7923-8115
