I want to do SVA checking on an asynchronous reset signal, if the reset is asserted the en signal must be 0 from the past 10 clock cycles before.
property(@(posedge clk) $fell(reset) |-> ($past(en,10) == 0));
The problem with the above snippet is the checking only happens on posedge of the clk but the reset is asynchronous which asserted non dependent to the clk. But the $past syntax wouldn’t have any clock reference if I didn’t put the clk.
Other than that, I believe this kind of way will affect the simulation performance.
If you guys have better way to suggest feel free to respond. Thanks in advance.
user49
November 4, 2022, 6:54pm
2
In reply to musyantsa :
You can use the endpoint for en==0 for 10 cycles.
First Synchronize the sync
Edit code - EDA Playground
module m;
bit en, reset_sync, reset, clk;
sequence s_en;
@(posedge clk) en==0[*10];
endsequence
ap_reset_en: assert property(@(posedge clk) $fell(reset) |-> s_en.triggered);
// Option: 1st synchonize the reset
always @(posedge clk) reset_sync <= reset;
// Use en==0 for 10 clocks starting from the synced reset
// Thus, you get 10+ clocks from the async reset
ap_resetsync__en: assert property(@(posedge clk) $fell(reset_sync) |->
s_en.triggered);
SVA Package: Dynamic and range delays and repeats SVA: Package for dynamic and range delays and repeats | Verification Academy
Free books:
Papers:
Understanding the SVA Engine,
Verification Horizons - July 2020 | Verification Academy
Reflections on Users’ Experiences with SVA, part 1
Reflections on Users’ Experiences with SVA | Verification Horizons - March 2022 | Verification Academy
Reflections on Users’ Experiences with SVA, part 2
Reflections on Users’ Experiences with SVA, Part II | Verification Horizons - July 2022 | Verification Academy
SUPPORT LOGIC AND THE ALWAYS PROPERTY
http://systemverilog.us/vf/support_logic_always.pdf
SVA Alternative for Complex Assertions
Verification Horizons - March 2018 Issue | Verification Academy
SVA in a UVM Class-based Environment
SVA for statistical analysis of a weighted work-conserving prioritized round-robin arbiter.
https://verificationacademy.com/forums/coverage/sva-statistical-analysis-weighted-work-conserving-prioritized-round-robin-arbiter .
