SVA $stable getting set at first cycle of the simulation
$stable is getting set at the very first clock event in the simulation even though the signal is stable .This is creating an unwanted attempt when I am trying to capture the actual changes in the data. I checked it with the following assertion
 	a_check_stable:assert property (@(posedge clk)
         $stable(d)) ;
which is the best method to resolve this issue?
In reply to vishnu_intel:
The general coding guideline in SVA is to use ##N delay when using $rose/$fell/$stable/$past etc. In your example do:
        ##1 $stable(d)) ;
Are you checking for a stuck-at-1/0 value on d here?
Regards
Srini
www.verifworks.com
In reply to Srini @ CVCblr.com:
I am trying to check whether a signal is asserted for minimum 3 clock edges for a synchronizer. I used something like this
property d_stable;
@(posedge clk) disable iff(!clr_b )
!($stable(d))  |=> $stable(d) [*2];
endproperty : d_stable
The above code shows false attempt at the beginning of the simulation.
Then I tried this code, which I think is working
property d_stable;
!($stable(d) || $isunknown($past(d)))  |=> $stable(d) [*2];
Though your second solution would do the job, the recommended coding style is to use ##N in the antecedent.
property d_stable_better;
##3 !($stable(d))  |=> $stable(d) [*2];
endproperty : d_stable_better
Rationale - with $stable/$past etc. you infer a memory/FF. As a good designer you want to take care of initial values and in this case you are delaying the checking by 3 clocks as per the user scenario. Also some formal tools require this style to formally verify assertions.
Good Luck
Srini
www.verifworks.com
