came across with this question online and have no good idea about requirement #2:
requirements:
1.once req asserted, ack should be asserted within 1-5 cycles, uniqueness here is required.
2.with out req, ack should not be asserted. In other words, every ack should have its corresponding req from past 1-5 cycles, “uniquely”. note there could be multiple outstanding req/ack pair
for 1st requirements, it’s easy to implement with the “now serving, tkt X” style from assertion handbook
int tkt, now_serving;
function void inc_tck();
tkt = tkt + 1'b1;
property p_req_ack;
int v_serving_tkt;
(req, v_serving_tkt = tkt, inc_tkt()) |=> ##[1:5] ack && now_serving == v_serving_tkt;
assert property(p_req_ack) now_serving = now_serving+1;
else now_serving = now_serving+1;
But I’m now sure what’s the best way to implement 2nd requirement which is basically the reverse direction of uniqueness;
Jeff
user49
February 11, 2022, 7:00am
2
In reply to Jeff_Li_90 :
2.without a req, ack should not be asserted. In other words, every ack should have its corresponding req from past 1-5 cycles, “uniquely”. note there could be multiple outstanding req/ack pair
This was answered without the uniqueness at
I have a simple spec “A grant must at some time have been preceded by a request” If grant arrives and request never arrives before grant, the assertion fails. Need to look in the past for request, but would not know when request would have arrived. ...
sequence s_ack; @(posedge clk) ##[1:5] ack; endsequence
ap_grant2: assert property(@(posedge clk) $rose(req) |-> ! s_ack.triggered);
For your issue, addressing your 2nd concern see code below: Key elements:
// Keep track of the number of request counts, +1 if req, -1 if ack
// Define a sequence to create endpoints in the last 5 cycles if rose(req)
// At new ack, then req count>0 and there was a req in the previous 5 cycles.
I believe that this would work, but I could have missed something.
Let me know if that is the case, but this is my current train of thoughts.
timeunit 1ns; timeprecision 100ps;
`include "uvm_macros.svh" import uvm_pkg::*;
bit clk, req, ack;
int req_count;
always @(posedge clk) begin
if(req) req_count <= req_count + 1'b1;
if(ack) req_count <= req_count - 1'b1;
sequence s_req; @(posedge clk) $rose(req) ##[0:5] 1'b1; endsequence // endpoints at 0, 1, ..5 cycles after req
ap_ack2req: assert property(@(posedge clk) $rose(ack) |-> req_count > 0 && s_req.triggered);
bit v;
repeat (200) begin
@(posedge clk);
req <= 1'b1; @(posedge clk); req <= 1'b0;
repeat(3) @(posedge clk);
ack <= 1'b1; @(posedge clk); ack <= 1'b0;
repeat(8) @(posedge clk);
repeat(2) @(posedge clk);
repeat(1) @(posedge clk);
repeat(9) @(posedge clk);
if (!randomize(req, ack) with {
req dist {1'b1 := 1, 1'b0 := 1};
ack dist {1'b1 := 1, 1'b0 := 3};
v dist {1'b1 := 1, 1'b0 := 5};
}) `uvm_error("MYERR", "This is a randomize error");
if(v) begin @(posedge clk) req <= 1'b1; repeat(6) @(posedge clk); end
$finish;
SVA Package: Dynamic and range delays and repeats SVA: Package for dynamic and range delays and repeats - SystemVerilog - Verification Academy
Free books: Component Design by Example https://rb.gy/9tcbhl
Papers:
Udemy courses by Srinivasan Venkataramanan (http://cvcblr.com/home.html )
user49
February 11, 2022, 7:29pm
3
In reply to ben@SystemVerilog.us :
OOPS! Need to correct the counters
Note: if req and ack are both true you get 2 NBA assignments to the same variable with different values; the simulator may accept the last one, and it will not function as intended.
NEW CHANGE:
if(req && !ack) req_count <= req_count + 1; // was if(req) ... * 1'b1
if(ack && !req) req_count <= req_count - 1; // was if(ack) ... - 1'b1
Updated code at http://systemverilog.us/vf/unique_ack.sv
This is a clever solution to workaroud the uniqueness requirement! Thank you Ben.
