I would like to write assertion check between dma_req and dma_burstend.
spec1; dma_req is high for two clk_sys, where as dma_burst_end is for one clk_sys
spec2: Dut should not generate another dma_req until “dma_burstend received for current dma_req”
for two clk_sys dma_req check , does following works
property dma_req_check();
@(posedge of sys_clk)
$rose(dma_req)|-> (dma_req[*2] ##1 !dma_req)
@(posedge clk)
$rose(dma_req)|-> (dma_req[*2] ##1 !dma_req);
means that if @t0 $rose(dma_req)==1 then @t0 dma_req ==1 // one repetition @t1 dma_req ==1 // 2nd repetition at next cycle @t2 dma_req ==0 //
$rose(dma_req)|=> (dma_req[*2] ##1 !dma_req);
means that if @t0 $rose(dma_req)==1 then @t1 dma_req ==1 // one repetition @t2 dma_req ==1 // 2nd repetition at next cycle @t3 dma_req ==0 //
Thus, you need
To upload, you’ll need an area to share.
google drive is a good place. I use my site, since I have access to it.
You should be able to attach a .jpg or .pdf to a post
How do you do this?
Both LINK or PICTURE icons (above the square box) require a url
Dave, in your reply, please attach the image that is in this link, and explain to me how you did it.
Maybe I am missing something.
With this new code assertion is getting failed(as expected).
But i am not able to understand it’s execution , in either case the ANTCDENT started 15ns, but as per my understanding $rose(dma_req) happened at 5ns so i am expecting that ANTCDENT should start from 5ns itself(please look at wave).
module test;
bit clk,dma_req,dma_burstend;
always #5 clk=~clk;
property dma_req_check;
@(posedge clk)
ap_dma2cycles1: assert property (dma_req_check);
property dma_req_check2;
real t,t_now;
real t2=20;
@(posedge dma_req) (1,t=$realtime) |-> @(negedge dma_req)(1,t_now=$realtime) ##0 ((t_now-t)==20);
ap_dma2cycles2:assert property(dma_req_check2);
initial
#5;
dma_req=1;
#20;
dma_req=0;
#30;
$finish;
endmodule // test
With above code (dma_req is high for 2 clk followed by low),those two assertions has to pass , but ap_dma2cycles1 reporting failure which is wrong.
Here i am suspecting that $rose(dma_req) is not captured at 5ns that is why it is behaving like that, because of this ANTCDENT started at next posedge of clk which at 15ns.
All signals are sampled in the Preponed region (see 1800’2012 4.4 Stratified event scheduler), just before the clocking event. If you do the analysis, you’ll see that it works OK, as expected.
Ben SystemVerilog.us
how did you enable “Assertion thread view” in questa .
From the assertion window. Click on the assertion and do a right-mouse click. It’s on the menu.
I compile with vlog -vopt -assertdebug -sv
I sim with vsim -vopt -assertdebug
