I have a property to check if the data is stable while some signal is zero, something like:
~arb |=> $stable(data)
This is true only if a clear signal is not activated.
I am using a flop to store a flag if the clear signal is asserted during the transaction, and checking it in the precondition:
~arb & ~is_cleared |=> $stable(data)
I don’t like this solution, is not elegant and it needs many logic to manage the flop load and clear.
Any idea of how to do it only with SVA in a better way?
In reply to meleth:
Support logic is often used in assertions. I don’t see anything wrong with it.
You may want to consider the sync_accept_on or the asynchronous accept_on where when the expression is true, the assertion is vacuous. FOr example:
ap_accept_disable : assert property (@ (posedge clk)
disable iff (!reset_n)
sync_accept_on (A_signal) // maybe something used in the generation of "is_cleared"
!arb |=> $stable(data));
I hate the use of the unary “~” for logical negation because the “~” has a different connotation.
Ben Cohen http://www.systemverilog.us/ben@systemverilog.us
In reply to meleth:
Yes, of course there it nothing wrong to use logic, but I always try to reduce it as much as possible. The sync_accept_on was exactly what I was looking for,
