Hi all,
I have a UVM testbench with following classes and need your suggestions to overcome the problem I’m facing.
class register_model extends uvm_reg_block;
rand reg_set_1 reg_1;
rand reg_set_2 reg_2; //This is a replica of reg_set_1 but with a different base address and is added newly
build();
endclass : register_model
class custom_reg_model extends register_model;
//constraints on reg_1 to control the randomization of register values
constraint enable_value
reg_1.enable.value == 1;
endclass : custom_reg_model
uvm_reg_block reg_set_2 is added recently and is a replica of reg_set_1. I need all the constraints I wrote for reg_set_1 to be applicable for the new reg_block(reg_set_2) as well.
What would be the recommended way to handle this scenario?
I tried the following but I’m not able to get the required behaviour:
- Create multiple instances of custom_reg_model and use factory override(set_inst_override_by_type) to override reg_model_1 with reg_model_2 based on the instance name. In this way each instance of the custom_reg_model will be responsible for a particular reg_block. Since reg_model_2 is not extended from reg_model_1, this approach didnt work.
- Second approach I had in my mind was to make the class custom_reg_model parametrized by passing the type while we create multiple instances. But effort wise, this is not easy to accomodate as current testbench doesnt have parametrized classes
- Another approach was to develop a custom copy method so that a dummy handle in custom_reg_model will do the randomization and copy the contents to appropriate reg_blocks based on the instance ID. I terribly failed to execute this as I didnt find a method to set the register values back to a handle. I used reg_1.get_registers(registers) to get all the registers. But didnt find any such method to set the registers to another reg_block. Any suggestions on this approach are welcome.
SV_UVM_49
