I have following requirement ::
Once a read has been issued , another read for the same readID cannot be re-issued until a readAck with the same ID has returned
I coded the following :: EDA_LINK
I have 2 questions ::
**I expected the assertion to PASS at TIME : 85 whereas I Observe that the assertion PASSes at TIME : 25 .
[Q1] Any suggestions why is it so ?**
**[Q2] not operator changes the strength as per LRM .
What's the strength of the Consequent in the above code .**
user49
2
In reply to hisingh:
You do not need the use of the not. State what the what IS rather than what is NOT.
property CheckRead ;
int localID ;
($rose( read ) , localID = readID ) |=>
!($rose(read) && readID==localID) [*1:$] ##0
$rose(readAck) && readAckID == localID;
My corrections:
BTW, you use too many () and too many spaces; it makes the code unreadable.
- SVA Package: Dynamic and range delays and repeats SVA: Package for dynamic and range delays and repeats - SystemVerilog - Verification Academy
- Free books: Component Design by Example https://rb.gy/9tcbhl
- Papers:
Hi Ben ,
As you pointed using Unary logical negation operator ( ! ) is the correct way .
However I wanted to know how the assertion behaves using not operator ::
int localID ;
( $rose( read ) , localID = readID ) |=> not( $rose( read ) && ( readID == localID ) ) [*1:$]
##0 ( 1 , $display("TIME : %2t Part1 Completes ", $time) )
##0 ( $rose( readAck ) && readAckID == localID )
##0 ( 1 , $display("TIME : %2t Part2 Completes ", $time) ) ;
I observe with the Same Stimulus as Original question , neither of the 2 $display() are executed in the consequent .
The Assertion passes at TIME : 25 even though ##0 ( $rose( readAck ) && readAckID == localID ) isn’t True
[Q1] I am not sure why however
[Q2] Also I would like your take on when to use not operator and when should one use negation !
