Previous-value of sampling time in SVA
I want to check whether a particular clock has a 50% duty cycle or not. And also intend not to use any local variable inside the property. To do this, I was pondering the possibility of using the $past function. Can we get the previous sampling value using this?
property answer (int clk_period);
@(posedge clk or negedge clk)
(clk_period/2) == ($time - $past($time , 1));
  • Can I get the desired answer using this property?
In reply to Shubhabrata:
When in doubt, run a test.
What does $past($realtime, 1, 1, @(clk)) mean?
$realtime is a system function that returns the current time.
Unlike a variable, it has no storage.
/ $past(expr1     [, number_of_ticks]     [, expr2] [,clk_evnt])
    assert property(@(clk)
     (clk_period/2) == ($realtime - $past($realtime , 1)));
      always @(clk) $display("rt= %t, past_rt=%t",
          $realtime, $past($realtime, 1, 1, @(clk)));
 // Results
rt=                   20, past_rt=                   0
"testbench.sv", 12: top.unnamed$$_1: started at 2000ps failed at 2000ps
	Offending '((10.000000000000000 / 2) == ($realtime - $past($realtime, 1)))'
rt=                  100, past_rt=                   0
"testbench.sv", 12: top.unnamed$$_1: started at 10000ps failed at 10000ps
rt=                  120, past_rt=                   0
  2. Free books: * Component Design by Example https://rb.gy/9tcbhl
  1. Papers:
