Pattern
How to generate a pattern 123454321
In reply to Vikas Misra:
rand bit [2:0] a[9];
constraint condition{foreach(a[i])
                       {if(i<=4)a[i]==(i+1);
                        else a[i] == (9-i);
In reply to Shubhabrata:
I written the code
class numbers_sequence;
 rand bit [2:0] numbers[9];
  constraint const_c {
                      foreach(numbers[i])
                      {if(i<=4) numbers[i]==(i+1);
                       else numbers[i]==9-i;
  numbers_sequence o;
  initial
     o=new();
     o.randomize();
      $display("the numbers: %p",o.numbers);
but result
the numbers: '{1, 0, 7, 6, 5, 4, 3, 2, 1}
For me, it’s working.
I am getting the required output.
foreach(numbers[i])
numbers_sequence o;
initial
o=new();
o.randomize();
Ouput :
vsim -voptargs=+acc=npr
run -all
the numbers: '{1, 2, 3, 4, 5, 4, 3, 2, 1}
exit
It looks like the tool you are using has a bug using if/else in a constraint.
Use an implication instead of if/else. I prefer that anyways so my constraints do not look like procedural code.
    foreach(numbers[i]){
      i<=4 -> numbers[i]==(i+1);
      i>4 -> numbers[i]==9-i;
Thanks Dave it is working.
