Pattern Detector 10110 in SV (no FSM)
Q. Write Code for Pattern Detector 10110. Input to DUT is 1 bit and output is 1 bit.
How can I implement without queue?
If I change queue to array in below code I get flag=1 twice. Why?
EDA Link: EDA Playground
Design.sv
NOTE: For **synthesizable RTL**, replace this with a fixed **5-bit shift register**
module pattern_detect(input clk, input rst, input bit in, output flag);
  logic  pat_seq[\$]='{1,0,1,1,0};
  logic  pat_in[\$]='{0,0,0,0,0};
  reg  flag=0;
  always @(posedge clk) begin
    if(!rst) begin
      pat_in.pop_front();
      pat_in.push_back(in);
//Issue with using array
//      pat_in[4]<=pat_in[3];
//      pat_in[3]<=pat_in[2];
//      pat_in[2]<=pat_in[1];
//      pat_in[1]<=pat_in[0];
//      pat_in[0]<=in;
      if(pat_in == pat_seq) begin
        flag <= 1;
        $display(" *************************** ");
        $display("flag is 1 @time=%0d", $time);
        foreach(pat_in[i]) begin
          $display("pat_in[%0d]=%0d", i, pat_in[i]);
        $display("***************************");
      else begin
        flag <= 0;
        $display("flag is 0 @time=%0d", $time);
    if(rst)
      flag <=0 ;
**[u]Testbench.sv[/u]**
module test;
  reg clk=0;
  reg rst=1;
  reg in=0;
  wire flag;
  pattern_detect pat(.clk(clk), .rst(rst), .in(in), .flag(flag));
    forever begin
    #10 clk = ~clk;
     // Dump waves
    $dumpfile("dump.vcd");
    $dumpvars(1, test);
    #10 rst=0;
        in=0;
    #20 in=1;
    #20 in=1;
    #20 in=0;
    #20 in=1;
    #20 in=1;
    #20 in=0;
    #20 in=1;
    #20 in=0;
    #20 in=0;
    #20 in=1;
    #20 in=0;
    #20 in=1;
     $finish;
Log
flag is 0 @timetime=10
pat_in[0]=0
pat_in[1]=0
pat_in@timetime2]=0
pat_in[3]=0
pat_in[4]=0
flag i@timetime 0 @time=30
pat_in[0]=0
pat_in[1]=0
pat_in@time2]=0
pat_in[3]=0
pat_in[4]=1
fl@timetimeg is 0 @time=50
pat_in[0]=0
pat_in[1]=0
pat_in@time2]=0
pat_in@time3]=1
pat_in@time4]=@time
flag is 0 @time=70
pat_in[0]=0
pat_in@time1]=0
pat_in@time2]=1
pat_in[3]=1
pa@time_in@time4]=0
flag is 0 @time=90
pat_in[0]=0
pat_in[1]=1
pat_in@time2]=1
pat_in[3]=@time
pa@time_in[4]=1
flag is 0 @time=110
pat_in[0]=1
pat_in[1@timeat_in=1
pat_i@time[2]=0@timepat_in[3]=1
@timeat_in[4]=1
flag is 1 @time=130
pat_in[0@timeat_in=1
pat_in[1]=0
pat@timein[@time]=1
pat_in[3@time=1
pat_in[4]=0
flag is 0 @time=150
pat_in[0]=0
pat_in[1]=1
pat_i@timetime[2]=1
pa@time_in[3]=0
pat_in[4]=1
f@timeag is 0 @time=170
pat_in[0]=1
pat_in[1]@time1
pat_i@time[2]=@time
pat_in[3]=1
pat_in[4]=0
flag is 0@time@time=190
pat_in[0]=1
pat_i@time[1]=0
pat_i@time@time2]=1
pat_in[3]=0
pat_in[4]=0
flag is 0 @time=210
pat_in[0]=0
p@timet_in[1]=1
pa@ti@timee_in[2]=0
pat_in[3]=0
pat_in[4]=1
flag is 0 @time=230
pat_in[0]=1
pat_in[1]=0
pat_i@time[2]=0
pat_in[3]=1
pat_in[4]=0
$finish called from file “testbench.sv”, line 50.
Waveform
it would help if you used `ifdefs to show us exactly how you were running the modified code. You cannot use pop_front and push back on array.
You have race conditions because you are changing in at the exact same time as the posedge clock. Use non-blocking assignments or shift the test bench changes away from the clock edge.
