I have two parameters one is ENABLE_DISABLE and another is a number NUM_OF_INTERFACES.
Now when enable_disable is 1 it should generate blocks but when enable_disable is 0 then it should not generate any of the
parameter NUM_OF_INTERFACES=5;
parameter ENABLE_DISABLE=1;
Below code works well,
generate
for (i=0; i< (NUM_OF_INTERFACES); i++) begin: GEN_BLOCK
checker_interface monitor_if();
endgenerate
Below codes don’t work, where basically I want to generate blocks based on ENABLE_DISABLE value.
1)
generate
for (i=0; i< (NUM_OF_INTERFACES & ENABLE_DISABLE); i++) begin: GEN_BLOCK
endgenerate
generate
if (ENABLE_DISABLE == 1) begin
endgenerate
Anybody have an idea? Thank you.
In reply to megamind:
We can use conditional generate statement inside generate loop. We can create the instance of monitor_if based on the value of ENABLE_DISABLE inside a for loop. The below code will iterate NUM_OF_INTERFACES times and it will check the value of ENABLE_DISABLE for each iterator value.
module top();
parameter ENABLE_DISABLE=0;
genvar i;
generate
for(i=0;i<NUM_OF_INTERFACES;i++) begin: GEN_BLOCK
if(ENABLE_DISABLE) begin: GEN_EN_BLOCK
end // if
end // for
endgenerate
Alternatively, we can first check the value of ENABLE_DISABLE and then start the loop. This is same as 2nd point in your code.
module top();
genvar i;
generate
end // for
end // if EN_DIS
endgenerate
Refer to IEEE 1800-2012 Section 27.5 for more information.
In reply to sharvil111:
Thank you for your help. It works.
