Override parameters in SV package
I have this generic package file that has a parameter for a default ID. What is the proper way to override that parameter? Is it to declare another package with the same parameter and compile it first? or is there a keyword to use?
In reply to VerifEx:
There is no way to override a parameter in a package. You can declare a class in the package and override the class parameter when you reference the class.
Other things you can do:
You can create different versions of the same package and choose which version to compile.
You can use define a text macro on the command line that can be used by the package to set the parameter value.
Dave,
i have also ran into this problem recently. I have DUT with a fair amount of parameters/generics. I have created a shared package that links the changes in the generics to uvm test fields. Now i realise this won’t work.
Can you elaborate on that 2nd option? I haven’t had much need to play with text macros in SV so far.
Thanks!
In reply to Phill_Ferg:
my_package.sv:
package my_package;
parameter my_parameter = `MY_DEFINE;
endpackage
Om your compiler command line
compile my_package.sv +define+MY_DEFINE=4
You shouldn’t need -floatparamters since the parameter is comping from a compiled package, and you need to re-compile the package to change a parameter’s value. You’re getting into the territory of tool-specific behavior, and this forum is not tool specific support.
Agreed! I release i was close to the edge. Thanks for your help!
“You can declare a class in the package and override the class parameter when you reference the class”
could you please give an example for this?
i have a class in the package and the parameter is declared inside the class.
how to override that parameter?
In reply to Liiiiiz:
package my_package;
  class my_class #(int my_parameter);
    function int get_parameter;
       return my_parameter;
endpackage
import my_package::*;
   my_class#(1) c1=new;
   my_class#(2) c2=new;
     $display(c1.get_parameter);
     $display(c2.get_parameter);
As was stated earlier, SystemVerilog does not provide a mechanism to override parameters declared in the top-level of a package. You need to describe what you are trying to accomplish. See https://xyproblem.info/
Hi Dave, please find the problem (hopefully better explained)
I have a class cg_wrap which has parameters A1-A4 as defined below which are used in the covergroup cg_wrap_1. The task sample() for the covergroup cg_wrap_1 is called in the coverage_collector class.
My intention is to override the parameters A1 and A2 such that when the task sample() is called, the coverpoints should check the signal with parameter value A1=11, A2=12 and not A1=10 and A1=20.
package my_pkg;
import uvm_pkg::*;
`include "uvm_macros.svh"
class cg_wrap #(
  parameter A1 = 10,
  parameter A2 = 20,
   parameter A3 = 30,
   parameter A4 = 40
) extends uvm_sequence_item;
  `uvm_object_param_utils(cg_wrap))
  function new(string name="cg_wrap");
    super.new(name);
  covergroup cg_wrap_1 with function sample();
    cp_xyz : coverpoint xyz {
            bins min = {0};
            bins min_p1 = {1};
            bins max_m1 = { A1 - 1};
            bins max = { A1 };
    cp_abc : coverpoint abc {
            bins min = {0};
            bins min_p1 = {1};
            bins max_m1 = { A2 - 1};
            bins max = { A2 };
     endgroup
      function new(string name="cg_wrap_1");
         super.new();
         cg_wrap_1 = new();
         cg_wrap_1.set_inst_name($sformatf("%s", name));
      function void sample();
         cg_wrap_1.sample();
class coverage_collector extends uvm_subscriber#(uvm_sequence_item);
   `uvm_component_utils(coverage_collector)
  uvm_analysis_port #(uvm_sequence_item) to_receiver;
  cg_wrap pkt_cov;
      super.new(name,parent);
      to_receiver   = new ("to_receiver", this);
      pkt_cov = cg_wrap::type_id::create("cg_wrap");
   endfunction : new
   task run_phase (uvm_phase phase);
      `uvm_info("UVC","run_phase: Executing.   coverage_collector run_phase<<<",UVM_LOW)
    endtask : run_phase
  task sample_and_transmit();
         pkt_cov.sample();
         to_receiver.write(pkt_cov);
  function void write(uvm_sequence_item t);
   //placeholder
endclass : coverage_collector
endpackage : my_pkg
Thanks for this reply in this thread.
To be clear, `MY_DEFINE macro can be used throughout the testbench code, including other packages, tests, sequences, and the testbench module?
Are there limitations to using this method?
