//The code uses the OOPs based layered techniq for architecting the testbench.The result generated by the DUT are passed to the acoreboard through monitor. But the result generated by the reference model differs due to synchronization. Whats the issue?
Any suggestion will be appreciated.
//code link : fullcode link
//================ design ===============//
module adder(a,b,c);
input [3:0] a,b;
output [4:0] c;
assign c=a+b;
interface intr;
logic [3:0] a,b;
logic [4:0] c;
endinterface
//=============== test =================//
class transaction;
rand logic [3:0] a,b;
logic [4:0] c;
constraint c_a {a inside {[10:15]};}
constraint c_b {b inside {[0:9]};}
function dis(string name);
$display("----------%0s----------",name);
class generator;
int test_vector;
mailbox gen2drive;
mailbox gen2scr;
transaction txn=new();
function new(mailbox gen2drive,mailbox gen2scr);
this.gen2drive=gen2drive;
this.gen2scr=gen2scr;
task run(int test_vector);
for(int i=0;i<test_vector;i++)begin
if(!txn.randomize())
$display("transaction is not done");
else begin
gen2drive.put(txn);
gen2scr.put(txn);
txn.dis("[ Packet send ]");
#2;
class driver;
mailbox gen2drive;
virtual intr v_intr;
transaction trans;
int test_vector;
function new(virtual intr v_intr,mailbox gen2drive);
this.v_intr=v_intr;
trans=new();
gen2drive.get(trans);
v_intr.a=trans.a;
v_intr.b=trans.b;
#2;
trans.c=v_intr.c;
trans.dis("[ Packet received ]");
$display("%g a=%0d b=%0d sum=%0d",$time,v_intr.a,v_intr.b,v_intr.c);
class monitor;
mailbox mon2scr;
function new(virtual intr v_intr,mailbox mon2scr);
this.v_intr=v_intr;
this.mon2scr=mon2scr;
logic [4:0] c;
c=v_intr.c;
mon2scr.put(c);
#2;
class agent;//it contain monitor,generator,driver
mailbox mon2scr;
mailbox gen2scr;
mailbox gen2drive;
generator gen;
driver drive;
monitor mon;
function new(virtual intr v_intr,mailbox gen2scr,mailbox mon2scr);
gen2drive=new();//no upper level access
drive=new(v_intr,gen2drive);
mon=new(v_intr,mon2scr);
gen=new(gen2drive,gen2scr);
gen.run(test_vector);
drive.run(test_vector);
mon.run(test_vector);
join
class score_board;
mailbox mon2scr;
mailbox gen2scr;
generator gen;
transaction txn;
function new(mailbox gen2scr,mailbox mon2scr);
txn=new();
task check(int test_vector);
logic [4:0] exp_sum;
logic [4:0] calculated_sum;
gen2scr.get(txn);
mon2scr.get(calculated_sum);
exp_sum=txn.a+txn.b;
$display("calculated_sum=%0d,exp_sum=%0d",calculated_sum,exp_sum);
if(exp_sum==calculated_sum)
$display("PASS");
$display("FAIL");
#2;
class environment;
mailbox gen2scr;
mailbox mon2scr;
agent age;
score_board scr;
function new(virtual intr v_intr);
gen2scr=new();
mon2scr=new();
this.v_intr=v_intr;
age=new(v_intr,gen2scr,mon2scr);
scr=new(gen2scr,mon2scr);
age.run(test_vector);
scr.check(test_vector);
join
program test(intr i_intr,int test_vector);
environment env;
env=new(i_intr);
env.run(test_vector);
endprogram
module tb();
intr i_intr();
test ts(i_intr,5);
adder dut(.a(i_intr.a),.b(i_intr.b),.c(i_intr.c));
