Interview question on constraint
Can anyone plz help me with this constraint question…
Take a rand variable with array size 10,need to get unique values in each location without using unique keyword and for any of 2 locations we need to get same value?
In reply to burra thanuja:
module abc;
  class aa;
    rand int unsigned val[10];
    constraint s1 {
      foreach(val[i]){
        val[i] < 10;
        foreach(val[j]){
          if(i != j)
            val[i] != val[j];
    aa a1 = new();
    a1.randomize();
    $display(a1.val);
this is the way to generate the unique values with out using unique keyword
In reply to yourcheers:
thank you for ur reply. sir i too know how to generate the unique value but my question is not only to generate unique values but also for any of 2 locations we need to get same value?
if possible plz go through the question once and plz help me with it if you aware of it.
thank you in advance
There are many ways to do this, one way is to use the post randomization.
module abc;
  class aa;
    constraint s1 {
      foreach(val[i]){
        val[i] < 10;
        foreach(val[j]){
          if(i < 9 && j < 9 && i != j)
            val[i] != val[j];
        val[10] = val[$urandom_range(0,8)];
    aa a1 = new();
    a1.randomize();
    $display(a1.val);
Thanks you sir for helping with the answer.
module abc;
  class aa;
    rand int unsigned r_index1,r_index2;
    constraint s1 {
      r_index1 == inside {[0:9]};
      r_index2 == inside {[0:9]};
      r_index1 != r_index2;
      foreach(val[i]){ val[i] < 10; }
      foreach(val[i]){
        foreach(val[j]){
          if(i != j && i!=r_index1  && j!=r_index1)
            val[i] != val[j];
      val[r_index1] == val[r_index2];
    aa a1 = new();
    a1.randomize();
    $display(a1.r_index1, a1.r_index2);
    $display(a1.val);
Hi burra.,
Please refer below solution for ur doubt,
// Code your testbench here
// or browse Examples
  class test;
  rand bit[3:0]array[10];
  constraint cnst_array{
    foreach(array[i])
      foreach(array[j])
        if(i!=j)
          array[i] != array[j];
        //array[$urandom_range(0,9)]=array[$urandom_range(0,9)]; // below is alternate for
        //this solution
      int i=$urandom_range(0,8);
      array[i]=array[i+1];  //though itseems everytime alternate index will be having same
                            //values,that's fine as the main context is to have same value in
                            //any two different indexes.
  test t1;
     t1=new();
     t1.randomize();
     $display("array=%p",t1.array);
Result:=
array='{11, 6, 11, 9, 3, 13, 1, 8, 14, 5}
In reply to Yash_wanth12345:
$urandom_range(0,9) will return any number between 0 to 9, so there is no guarantee that you will always get different index values in LHS and RHS.
In reply to Alokpati:
HI,
Yes you are right.,
but we can do like below.,
though itseems everytime alternate index will be having same values,that’s fine as the main context is to have same value in any two different indexes.
in the post randomize both the indexes of lhs and rhs might randomize to be the same value and it won’t meet the criteria ‘2 values should be same’
eg: a[2]=a[2] can happen
In reply to sriram_madavswamy:
Hi @sriram.,
Please refer to the updated solution know.
module tb;
  class myClass;
    rand int a[10];
    constraint c_a_val {
      foreach(a[i]) {
        a[i] inside {[1:10]};
        if(i%2 == 0) {
          a[i+1] == a[i];
          foreach(a[j]) {
            if( (j%2 == 0) && (i != j) ) {
              a[i] != a[j];
      $display("a = %p", a);
    myClass obj = new();
    obj.randomize();
Probably, this should meet the query…
program tb;
class cls;
rand bit [3:0] arr[10], indx1, indx2;
constraint cons{
foreach(arr[i])
foreach(arr[j])
(i != j) → soft arr[i] != arr[j];
        indx1 inside {[0:9]};
        indx2 inside {[0:9]};
        indx1 == (indx2 + 1);
        arr[indx1] == arr[indx2];
    cls obj = new;
    repeat(2) begin
        obj.randomize;
        $display("indx1 = %d, ind2 = %d, arr = %p",
            obj.indx1,obj.indx2,obj.arr);
endprogram
In reply to VC_45:
program tb;
class cls;
constraint cons{
foreach(arr[i])
foreach(arr[j])
Please use code tags.
class unq_arr;
 rand int unsigned d;
 rand int unsigned arr[10];
 constraint arr_c{
   foreach(arr[i]) { arr[i] inside {[1:10]};}
   foreach(arr[i]) { arr.sum() with (int'(item==arr[i])) == (arr[i]==d ? 2:1);}
Shouldn’t there be an additional constraint to ensure d’s value is within arr ?
constraint INSIDE { d inside { arr } ; }
In reply to Have_A_Doubt:
It will work as solver should take care of it to satisfy the constraint.
Adding additional constraint on ‘d’ may help solver to solve constraint fast.
  arr[i]==d // it will force RHS to be equal to LHS, and 'd' doesn't have any constraint so it will work
There is No constraint ( direct / indirect ) however to ensure this .
The constraint solver could solve the equation ( arr[i]==d ) to be 0 always thereby giving only Unique elements .
Agree… got your point. And strange my code didn’t fail when ran for loop of 100(check added in post_randomize to validate number of unique element).
