class A;
rand bit[4:0] array[10];
rand bit[4:0] num1,num2;
constraint C1 { foreach(array[i]) foreach(array[j]) {if(i!=j) array[i]!= array[j];}}
constraint C2 {num1 !=num2; num1<10;num2<10;}
$display("post_randomize: num1=%d, num2=%d",num1,num2);
array[num1]=array[num2];
function print();
foreach(array[i]) begin
$display("arr[%d]=%d",i,array[i]);
foreach(array[j])
if(array[i]==array[j] && i!=j) $display("array[%d] and array[%d] matches",i,j);
module tb;
A a=new();
assert(a.randomize());
a.print();
In reply to burra thanuja:
Bellow is simple sollution i have written for the above problem
class my_rand;
rand bit [5:0] a[10];
rand int b,c;
constraint sum_new {
solve b,c before a;
foreach(a[i]){
if((i == b )|| (i==c) )
(a.sum() with(int'((item == a[i]))) ) == 2;
(a.sum() with(int'((item == a[i]))) ) == 1;
constraint n1{
b inside {[0:9]};
c inside {[0:9]};
c != b;
module mod ();
initial
my_rand me;
me = new();
me.randomize();
$display("%p",me.a);
You can get the address question with below code.
It’s working 100%.
Array = '{'h0, 'h1, 'h2, 'h2, 'h3, 'h6, 'h7, 'h8, 'hb, 'he}
class ABC;
rand bit [3:0] array[10];
constraint a_c {
foreach(array[i]) {
if(i>0) {
if(i == 3)
array[i] == array[i-1];
array[i] > array[i-1];
module tb;
ABC abc;
abc = new();
abc.randomize();
$display("Array = %p", abc.array);
Here is performance friendly array randomization with 10 unique element values. In all above discussions, wherever we are using 2 foreach loops can be replaced with below code
class optimized_unique_array;
rand int array[10];
localparam int RANGE_START = 1;
localparam int RANGE_END = 100;
// Static pool created once and reused
static int pool[RANGE_END-RANGE_START+1];
static bit pool_initialized = 0;
function void pre_randomize();
if (!pool_initialized) begin
foreach (pool[i]) pool[i] = RANGE_START + i;
pool_initialized = 1;
pool.shuffle(); // Shuffle the existing pool
array = pool[0:array.size()-1]; // Take first N elements
//array of 10 elemets with 3 same elements and remainig should be unique
class array_constraint;
rand bit [7:0] arr[10]; // Array of 10 elements
rand bit [7:0] repeat_variable; // The repeated value
constraint repeat_count_c {
// Exactly 3 elements should be equal to repeat_variable
// arr.sum with (int'(item == repeat_variable)) == 3; //it will also work
arr.sum with (item==repeat_variable?1:0) == 3;
// Remaining 7 values must be unique and not equal to repeat_variable
foreach (arr[i]) {
if (arr[i] != repeat_variable) {
foreach (arr[j]) {
if (i != j && arr[j] != repeat_variable)
arr[i] != arr[j];
// Optional display
$display("repeat_variable = %0d", repeat_variable);
$display("arr = %p", arr);
module tb;
array_constraint ac = new();
repeat(5) begin
if (!ac.randomize())
$display("Randomization failed");
I think it is easy method
