Inout port illegal connection error
i have a inout port and i wanna assign it to other varibale at AL and top but it does not work.
Error : inout port illegal connection for port to reg type.
At AL.svh
inout [31:0] DATA;
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
At top.svh
AL AL_0(
.DATA(bus_if.DATA)
At bus_if.sv
logic [31:0] DATA;
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
i tried to fix much more but it does not work, could you help me? Thanks.
In reply to nrllhclb:
The port declaration
inout [31:0] DATA;
implies this is a nettype (wire). And you want to connect this to a simple variable in your interface. This is not legal.
In your SV interface declare
wire [31:0] DATA,
This’ll fix your problem.
unfortunately, i tried things which written by you, but it did not.
See here an example:
module des(input logic a, output logic b, inout wire c);
interface intf();
  logic x;
  logic y;
  wire z;
  //logic z;
endinterface
module top();
intf iface();
des DUT(.a(iface.x), .b(iface.y), .c(iface.z));
Replacing the wire in the interface with logic results in the error message:
inout.sv(15): Illegal inout port connection for ‘c’ (3rd connection).
Just remember that logic cannot be connect to inout~
