Let’s say there is one rand 10-bit variable named data. Now I want to make sure there won’t be 7 consecutive 0s or 1s. Can someone suggest me how can I constraint in such way ?
parameter width = 7;
constraint c_data
foreach(data[i])
(i < data.size() - width) -> !(data[i+:width] inside {'0,'1};
Hi Dave, can you help explain your constraint ? The right hand side of implication operator. If the data is declared as bit do we need inside operator?
class tb;
rand bit [9:0] data;
// I want to constrained random 10 bit such that there won't be 7 consecutive 0s or 1s. Can someone suggest anything ?
constraint c_data
foreach(data[i])
(i < $size(data) - width) -> !(data[i+:width] inside {'0,'1});
// i=0 ; (0 < 10 - 7) -> !data[0+:7] should not be inside 0 or 1
// i=1 ; (1 < 10 - 7 ) -> !data[1+:7] should not be inside 0 or 1
// i=2 ; (2 < 10 -7) -> !data[2+:7] should not be inside 0 or 1
module ab;
tb t1;
t1= new();
if (!t1.randomize()) begin
$display ("Randomize Error"); end
$display ("%b",t1.data);
