there is a requirement that b should be asserted after that and a is asserted and de-asserted ( there can be any number of clocks between b and a) and a can be asserted and de-asserted any number of times
please let me know how to write assertion for that.
In reply to srbeeram:
Rephrasing the requirements:
[list=1]
Following a new “b” signal “a” is asserted after any number of cycles. This is then followed by the signal “a” being deasserted after any number of cycles.
Thanks Ben for providing the answer. the answer you provide will give error if a is not asserted. but I dont need error if a is not asserted. please let me know how I can change the assertion for that.
I interpret this to mean: Following a new “b” signal “a” is asserted after any number of cycles. This is then followed by the signal “a” being deasserted after any number of cycles.
ap: assert property(
@(posedge clk) $rose(b) |-> a[->1] ##1 !a[->1]);
ap_same: assert property(
@(posedge clk) $rose(b) |-> !a[*0:$] ##1 a ##1 a[*0:$] ##1 !a);
ap_same2: assert property(
@(posedge clk) $rose(b) |-> !a[*0:$] ##1 a[*1:$] ##1 !a);
// above assertions says
// "b" should be asserted, after that "a" is asserted some time later and then
// "a" is de-asserted in any number of cycles.
// Note: b[->1] is equivalent to: !b[*0:$] ##1 b
You now say
the answer you provide will give error if a is not asserted. but I don’t need error if a is not asserted.
Your 2nd requirement contradicts the first that says after that and a is asserted and de-asserted. What is the relationship between “b” and “a”?
You can draw it, for example:
b 0 1 X ...X X X ...X X X X X X X X X X X
a X 0 0 ...0 1 1 ...1 0 X X X X X X X X X
property <---------------------------->
If you cannot express your requirements in English, you certainly cannot write an assertion for it.
