We want to verify a clock divider clocks(period , duty cycle and enable )using assertions .
do we need to write separate assertions for every clock period ,duty cycle etc.
clocks are related to each other like (div2, div4,div8,div16and so on). how to verify phase synchronization?
In reply to yoshiko:
/ We want to verify a clock divider clocks(period , duty cycle and enable )
using assertions. Do we need to write separate assertions for every clock period ,
duty cycle etc. clocks are related to each other like (div2, div4,div8,div16and so on).
how to verify phase synchronization? /
There are various methodologies to verify models.
Comming from an old school of thoughts, I recommend the verification of clocks divisions to be done as follows:
- Verify through code reviews that ALL THE DERIVED CLOCKED ARE SOURCED BY A MASTER CLOCK. I demonstrate that below with clk2, clk4, clk8
- Verify through simulation that the design functions as you intended.
- If the design is not modified, there is little need for assertions. However, it does not hurt to add assertions; I would do that as a low priority after the top 2 items are done. Clock periods, or better yet, duration LOW and durations HIGH for each clock could done, along with the synchronization of the clocks.
I demonstrated this in the model below. The randomization stuff is part of my testbench template I use to test assertions; it is not used here.
timeunit 1ns; timeprecision 100ps;
bit clk, clk2, clk4, clk8, a, b;
realtime clk_period= 20ns;
initial forever #10 clk=!clk;
$timeformat(-9, 1, "ns", 8);
$display("%t", $realtime);
always @(posedge clk) begin
clk2 <= !clk2; // div 2
if(clk2) clk4 <= !clk4;
if(clk2 && clk4) clk8 <= !clk8;
// Example of a frequency check
property p_clk_freq3;
realtime current_time;
@ (posedge clk)
// disable iff ( !(!(reset) && (flag)))
('1, current_time = $realtime) |=> (1, $display ("p=%t", $realtime - current_time))
##0 (($realtime - current_time) <= clk_period + 1ns && // logical and
($realtime - current_time) >= clk_period - 1ns);
ap_clk_freq3: assert property (p_clk_freq3);
// $past( expression1 [, number_of_ticks] [, expression2] [, clocking_event])
ap_clk2: assert property(##8 1'b1 |-> @ (negedge clk) !$past(clk,1,, @(posedge clk)));
// ##8 is to take care of the $past at startup. Use whateve ##n you need.
bit va, vb;
repeat(200) begin
@(posedge clk);
if (!randomize(va, vb) with
{ va dist {1'b1:=1, 1'b0:=3};
vb dist {1'b1:=1, 1'b0:=2};
a <= va;
b <= vb;
$stop;
- SVA Handbook 4th Edition, 2016 ISBN 978-1518681448
- Real Chip Design and Verification Using Verilog and VHDL, 2002 isbn 978-1539769712
- A Pragmatic Approach to VMM Adoption 2006 ISBN 0-9705394-9-5
- Using PSL/SUGAR for Formal and Dynamic Verification 2nd Edition, 2004, ISBN 0-9705394-6-0
- Component Design by Example ", 2001 ISBN 0-9705394-0-1
- VHDL Coding Styles and Methodologies, 2nd Edition, 1999 ISBN 0-7923-8474-1
- VHDL Answers to Frequently Asked Questions, 2nd Edition ISBN 0-7923-8115
See Paper: 1) VF Horizons:PAPER: SVA Alternative for Complex Assertions | Verification Academy
2) http://systemverilog.us/vf/SolvingComplexUsersAssertions.pdf
You can use the local variable in assertions and apply checks for consecutive rising edge and consecutive falling edge. For example : -
if you have to check div/VALUE , where VALUE=2 then you can write the following
property o_clk_even_rose_div(div_clk , n) ;
int local_cnte;
@(posedge i_clk ) disable iff (~div_reset_check)
($rose(div_clk[n]) ,local_cnte=0) |=> (1'b1,local_cnte=local_cnte+1)[*1:$] ##0 (local_cnte==VALUE/2) ##0 $fell(div_clk[n]);
similarly you can write for the falling edge this will take care of your duty cycle.
In the case of odd division type
apply the assertion for posedge and the negedge and local_cnt will be equal to VALUE and not VALUE/2 in case of odd division.
PS:CHECK FOR SYNTAX
Prashant
In reply to pk_94:
That assertion can never fail because of the [*1:$] as there are other threads to test if any thread fails.
Ben systemverilog.us
This assertion is properly working. Suppose for VALUE=4 ,that is div/4 ,the local counter will start incrementing , and when the local_counter is equal to value/2 , it will check the falling edge of the divider,and if the divider do not falls for that ,it will give error. I missed to apply the first_match above.It should be : -
($rose(div_clk[n]) ,local_cnte=0) |=> first_match((1'b1,local_cnte=local_cnte+1)[*1:$] ##0 (local_cnte==VALUE/2)) ##0 $fell(div_clk[n]);
In reply to pk_94:
($rose(div_clk[n]) ,local_cnte=0) |=> ((1'b1,local_cnte=local_cnte+1)[*1:$] ##0 (local_cnte==VALUE/2)) ##0 $fell(div_clk[n]);
If (local_cnte==VALUE/2) is true and in the same cycle $fell(div_clk[n] is false, the consequent will keep on trying for another thread. Specifically, an assertion of the form:
(a, v=k) |=> (1, v=v+1)[*1:$] ##0 v==x ##0 b; // is same as
(a, v=k) |=? (1, v=v+1)[*1] ##0 v==x ##0 b or
(1, v=v+1)[*2] ##0 v==x ##0 b or
(1, v=v+1)1[*3]##0 v==x ##0 b or
(1, v=v+1)[*n] ##0 v==x##0 b; // where n is infinity/
Thus, if any of the thread fails, the simulator will try other threads.
The first_match() traps the 1st good condition when v==x, and then tests of the b.
If b==0, assertion fails. thus,
(a, v=k) |=> first_match((1, v=v+1)[*1:$] ##0 v==x) ##0 b;
- VF Horizons:PAPER: SVA Alternative for Complex Assertions | Verification Academy
- http://systemverilog.us/vf/SolvingComplexUsersAssertions.pdf
- “Using SVA for scoreboarding and TB designs”
http://systemverilog.us/papers/sva4scoreboarding.pdf - “Assertions Instead of FSMs/logic for Scoreboarding and Verification”
October 2013 | Volume 9, Issue 3 | Verification Academy - SVA in a UVM Class-based Environment
I agreed. Then I can modify the following assertion to the following , where repetition is fixed depending on the VALUE.
($rose(div_clk[n]) ,local_cnte=0) |=> first_match((1’b1,local_cnte=local_cnte+1)[*(VALUE/2)])##0 $fell(div_clk[n]);
Here the repetition is fixed so for only one thread condition will be checked and if $fell is not met the assertion will fail.
In reply to pk_94:
//structurally, the first_match() is not needed here
($rose(div_clk[n]) ,local_cnte=0) |=> first_match((1'b1,local_cnte=local_cnte+1)[*(VALUE/2)])##0 $fell(div_clk[n]);
// But the above is same as
let MY_DELAY = VALUE; // VALUE is a constant
$rose(div_clk[n]) |=> ##MY_DELAY $fell(div_clk[n]);
Yes agreed , that first match is not needed here.
I also tried your solution but it gives me compile error : -
property even_rose_div(clk_div , n) ;
let MY_DELAY = VALUE[2*n+:2] ; // VALUE is a constant
Here value is coming from parameter ,where n is an argument. But it is giving me compile error.
*E :- Expected specification terminator “;”.
I think the local variable is the best way to check divider.
In reply to pk_94:
I did not write a separate property, just a direct assertion.
If you need arguments, then write a full property
let n=3;
property p_even_rose_div(clk_div , n) ;
ap_even_rose_div: assert property(p_even_rose_div(some_clk, 4);
// syntaxed not checked, looks OK though
If you want dynakic delay, see my papers (1 and 2 referenced below).
Hi Ben,
Could you please let me know in brief of the below mentioned line.
ap_clk2: assert property(##8 1’b1 |-> @ (negedge clk) !$past(clk,1, @(posedge clk)));
In reply to sudharshan:
Iwouldn’t use that assertion.
Ben
for a clock divider circuit by 3/5/7… is it possible to write a generic property
please help me out
Thanks in advance
Kind regards,
Sudharshan
Assuming your clock divider provides a single master clock pulse every 3rd, 5th, 7th clock
bit clk, b, c; // b is divide by 3, c is divide by 5
property divide(bit a, int n);
@(posedge clk) $rose(a) |=> !a[*n-1] ##1 $rose(a);
ap_div3: assert property(@ (posedge clk) divide(b, 3);
ap_div5: assert property(@ (posedge clk) divide(c, 5);
- SVA Alternative for Complex Assertions
https://verificationacademy.com/news/verification-horizons-march-2018-issue - SVA: Package for dynamic and range delays and repeats - SystemVerilog - Verification Academy
Hi Ben,
Could you please help me understand what is “b” and “c” in the above property? I can see that you are already using “clk” (which I believe is the master clock pulse)
