Hi, I have a register with 29 bits, the default value is all 0.
I would like to write an assumption whereby all bits are 1 except one of the bit is 0.
For example, 29’h3FFF_FFFE
I would like to have the value 0 being cycle through bit 0, bit 1, bit 2…bit 29
Is anyone can help to provide the solution in systemverilog assertion?
In reply to wendy:
If you just like to check only one bit is 0, you could use $countones function, in this case, $countones(bus) == 28.
In reply to wendy:
property count1(clk1, val1);
int unsigned prvidx = 0;
@(posedge clk1)
($countones(var1) === ($bits(var1) - 1)) |-> ($clog2((~val1)) === prvidx + 1, prvidx = $clog2((~val1)), $display("val1 = %b prvidx =%d", val1, prvidx));
endproperty : count1
can you try this?
thanks!
Nilesh Patel
In reply to plin317:
In reply to wendy:
The following should work.
property bchk0;
logic [28:0] old;
@(posedge clk) disable iff (!rstN)
(1’b1, old = bus) |=>
if (bus == old)
($countones(bus) == 28)
(($countones(bus) == 28) && ( bus == {old[27:0], old[28]} ));
assert property(bchk0);
how to check that on which address, the bit value is 0?
Use a for
loop.
