task force_bit(input bit [3:0]ramr , input bit [31:0] c_dword); //{ // ramr 0 to 7, c_dword 0 to 4;
//genvar ramr_loc;
//ramr_loc = ramr;
`ifdef ASIC
//generate
force <initial_path>.m_65536x156_inst.RAMR[ramr /*ramr_loc*/].V.C[c_dword].A.<inst_name>.Mem[0][1] = 1'b1;
//endgenerate
`endif
endtask //}
xmelab: *E,NOTPAR : Illegal operand for constant expression [4(IEEE)].
In reply to m_r_m:
use generate block
In reply to Jeff_Li_90:
I think we will not be able to use generate block inside the method?
In reply to m_r_m:
virtual class abs_intf;
pure virtual task my_force;
pure virtual task my_release;
module tb;
genvar i;
logic a[4]; //signal to be forced
generate
for(i = 0; i < 3; i ++) begin
class utility_force_release extends abs_intf;
task my_force;
force tb.a[i] = 1;
task my_release;
release tb.a[i];
utility_force_release tmp;
tmp = new();
my_intf[i] = tmp; // Just for illustration.
// config_db to uvm side if needed.
endgenerate
function void my_display();
$display("a[0]:%0h, a[1]:%0h, a[2]:%0h, a[3]:%0h", a[0],a[1],a[2],a[3]);
abs_intf my_intf[4];
my_intf[2].my_force;
my_display();
In reply to m_r_m:
or another way if you are using uvm is to go with uvm_hdl_force/release methods, which takes string based paths at run-time. only concern is if you can stand the slowdown.
