hii everyone,
i want to assign adress for all the slaves from master but condition is that no address should repeat ,
means unique adress should be for each slave.
please provide me system verilog logic(code).
hii everyone,
In reply to raj@123:
class a;
parameter N = 10; //no of slaves
rand int unsigned add[N];
constraint unique_add { unique{add};}
// if needed end address take another array of same size and add parameter(no of bytes) to the add array and use start and end address
module tb;
a a1;
initial
a1 = new;
a1.randomize;
$display("%p",a1.add);
In reply to sasi_8985:
class a;
module tb;
a a1;
initial
a1 = new;
a1.randomize;
what is the meaning of this line:- // if needed end address take another array of same size and add parameter(no of bytes) to the add array and use start and end address.
please explane
Don’t we have address ranges(i.e sizes) for each slave?
In reply to Desam:
class a;
parameter width = 4;
int slaves_width[N];
rand int unsigned add[N],end_[N];
constraint size { foreach(end_[i])
end_[i] == add[i] + this.slaves_width[i]; }
function void pre_randomize( int slaves_width[N] );
// this is to take width of slaves before
//hand
foreach(slaves_width[i])
this.slaves_width[i] = slaves_width[i];
module tb;
a a1;
int aa[10] = '{10{4}};
initial
a1 = new;
a1.pre_randomize(aa);
a1.randomize;
$display("%p *** %p",a1.add,a1.end_);
BUT I am sure there is an other way which i am not aware of. lets wait and see.
In reply to Desam:
class a;
//hand
module tb;
a a1;
initial
a1 = new;
a1.randomize;
and one more thing i would like to generate 10 address according to my restriction means i have some restricted address list how to perfom this this.
for exaple i would like to generate 10 random slave slave address from 40 to 50
Plz look at code and hope it helps:
Here is an example for non-overlapping slave address. I assumed one slave is 1K in size and the 2nd slave is 2K is size. You can extrapolate and come up with more conditions if we have a 3rd slave but the idea should work. we solve slave1 before slave2 and so on to have a reference to work out the math for the other slave range. you can also use more constraints dep on what we are trying to accomplish. This ensures the non-overlapping part
// Code your testbench here
// or browse Examples
class packet;
int global_start=0;
int global_end=8192;
rand bit [12:0] S1,E1,S2,E2;
//assume slave1 size is 1K
constraint slave1 {
S1 >= 0;
S1 <= 7168;
E1 < 8192;
E1-S1 + 1 == 1024;
//solve slave1 range first to help having a reference for non-overlapping slave address
constraint solve1 {solve S1 before S2;}
constraint solve2 {solve E1 before E2;}
//assume slave2 size is 2k
constraint slave2{
S2 >= 0;
E2 < 8192;
E2-S2+1==2048;
if(8192-E1 < 2048)
E2 < S1;//as we don't have enough width for a slave2 range after E1 through 8192
E2 == S2 + 2047;
if(8192-E1 >2048)
S2 > E1;
S2 + 2048 < 8192;
module test;
packet p1=new();
repeat(2) begin
if (p1.randomize()) begin
$display("S1 %0d is E1 is %0d",p1.S1,p1.E1);
$display("S2 %0d is E2 is %0d",p1.S2,p1.E2);
else $display("Randomization failed!");
