Could you please let me know how to write a signal is going high once using system verilog assertion. could you please let me know the following code is correct.
module one;
int a ,b,clk;
initial
forever
#5 clk=~clk;
#1000ns $finish;
#5 a=1;
property rstcheck(logic a);
firstmatch( ##[1:$] $rose(a));
first:assert property ( @( posedge clk)rstcheck(a));
timeunit 1ns; timeprecision 100ps;
bit clk, a, b=1, c=1, reset_n;
default clocking @(posedge clk);
endclocking
#100 @(posedge clk) a <=1'b1;
// #1000 a <= 1'b0;
let max= int'(1.0E30);
initial ap_a_once_ever: assert property(@ (posedge clk)
$rose(a) [->1] |=> strong(a[*max]));
// will fail if a==0 or at end of sim
#2000;
$finish;
endclocking
// #1000 a <= 1'b0;
#2000;
$finish;
I tried this and it works when a gets de-asserted, but it also fails initially when a is zero for some time. So, in my simulation a is zero from the start of the simulation and gets asserted after a point. So, I want this assertion to capture the bug - i.e. whenever a falls after it goes high.
bit a_rose, a_fell;
task automatic t_a;
@($rose(a, @(posedge clk))) begin
a_rose=1'b1;
// fork
@($fell(a, @(posedge clk))) begin
`uvm_error("MYERR", "a fell ");
a_fell=1'b1;
//join
initial t_a();
final begin
$display("%t at final", $realtime );
if(a_rose && a_fell) $display("%t a_rose and fell", $realtime );
FOr some reason the final message is not displayed. I’ll let you debug that
