Hi all,
I want to check clock frequency by asssertion, but there is a problem, the ‘valid’ signal is not sinchronized to the clock, so when it de-assert, the assertion already in the middle of checking the expression. In this case I will get an error message at time that the ‘valid’ is 0.
Is there any option to mask the error message in case that ‘valid’ deassert or to check tha ‘valid’ value before the second waiting to the clock rising edge?
Original code:
property p_clk_freq;
time rising_time;
@(posedge clk) disable iff (!freq_valid)
(1, rising_time=$time) |=> @(posedge clk) ($abs(int’(($time-rising_time))-int’((period*1.0ps)))<= TOLERANCE);
In reply to Yehu:
Why do you say In this case I will get an error message at time that the ‘valid’ is 0.?
The disable iff is asynchronous. 1800’16.12 Declaring properties
The expression of the disable iff is called the disable condition. The disable iff clause allows preemptive resets to be specified. For an evaluation of the property_spec, there is an evaluation of the underlying property_expr. If the disable condition is true at anytime between the start of the attempt in the Observed region, inclusive, and the end of the evaluation attempt, inclusive, then the overall evaluation of the property results in disabled. A property has disabled evaluation if it was preempted due to a disable iff condition. A disabled evaluation of a property does not result in success or failure.
Otherwise, the evaluation of the property_spec is the same as that of the property_expr. The disable condition is tested independently for different evaluation attempts of the property_spec. The values of variables used in the disable condition are those in the current simulation cycle, i.e., not sampled. The expression may contain a reference to an end point of a sequence by using the method triggered of that sequence. The disable conditions shall not contain any reference to local variables or the sequence method matched. If a sampled value function other than $sampled is used in the disable condition, the sampling
clock shall be explicitly specified in its actual argument list as described in 16.9.3. Nesting of disable iff clauses, explicitly or through property instantiations, is not allowed
Another option is explained in 1800’2017 16.12.14 Abort properties
A property is an abort if it has one of the following forms:
For an evaluation of accept_on (expression_or_dist) property_expr and of
sync_accept_on (expression_or_dist) property_expr, there is an evaluation of the underlying
property_expr. If during the evaluation, the abort condition becomes true, then the overall evaluation of the property results in true. Otherwise, the overall evaluation of the property is equal to the evaluation of the property_expr.
One more note on making the disable iffsynchronous:
From my SVA book: Sampled value Function: If a sampled value function other than $sampled is used in the disable condition, the sampling clock must be explicitly specified in its actual argument list. Thus, the following is legal:
**Nesting:**Nesting of disable iff clauses, explicitly or through property instantiations, is not allowed. The disabling condition must only appear at the top level of an assertion. It cannot be nested; this is unlike the accept_on, reject_on, sync_accept_on, sync_reject_on operators that allow nesting (see 3.9.2.14). The following nesting of disable iff example is illegal:
assert property ( @ (posedge clk) disable iff (cancel)
pXY(req, ack, reset)); // pXY has a disable iff
Thank you for your reply.
One more question:
If I understand correctly, accept_on means that if the expression that comes after it is true, the propery_expression will be sampled. So in my case I have to use reject_on(!freq_valid), Or accept_on (freq_valid).
There are 2 variations of the accept, the asynchronous and the synchronous.
accept_on ( expression_or_dist ) property_expr // asynchronous, whenever it occurs
sync_accept_on ( expression_or_dist ) property_expr // sampled
Thus, whenever the !freq_valid==1 the assertion is true.
See this simple test
In reply to Yehu:
Hi Ben,
is that extra @(posedge clk) needed on the RHS of non overlapping implication operator? I believe it adds one more clock cycle to the calculation.
That extra @(posedge clk) is NOT needed on the RHS of non overlapping implication operator. It is not needed because the initial clocking event (i.e., the one in the @(posedge clk) disable iff (!freqed_valid)) flows through to the consequent.
And NO, that extra @(posedge clk) does not adds one more clock cycle to the calculation. That extra clocking event is typically used in multiclocking. Fro example:
If you use the same clocking, it is considered a multiclocking where the 2nd clocking event is in sync with the first.
BTW, I had it because I copied your assertion and was concentrated on your initial problem of block error message and not the assertion itself. Actually, you do not needed and it is confusing if you do add it. Remeber, the clock flows from the antecedent to the consequent.
SVA has specific rules on clock flow and sequences. The LRM explains them, and I demonstrate them in my SVA BOOK (4.3 Clocked Sequences, Properties, And Multiclocking).
Ben SystemVerilog.us
