Help in finding better way to restructure the code
I have a logic where a semaphore waits for key only if a particular condition is not set and once I gather the key, I release after clocking block statement one cycle later. However, if a condition is set, therefore, it checks in next cycle for the key. I think my implementation in the code is too clumsy. The issue in this logic is that when we check for key every cycle, we might miss the key as the thread which releases the lock runs later and we get the lock in next cycle. Therefore, I need help re-structuring the code and the logic is shown below.
forever begin
  while(condition_set)
    @(cb);
  if(try_get())
    break;
    @(cb);
drive some signals
@(cb);
put();
In reply to rahulkumarbudhwani:
See if this model provides some answers for you.
http://systemverilog.us/vf/sem.sv
    timeunit 1ns;  timeprecision 100ps;
    `include "uvm_macros.svh"
    import uvm_pkg::*;
    bit clk, cond;
    semaphore smTx;
    event e1, e_other;
    initial  smTx=new(1);
    default clocking @(posedge clk);
    endclocking
   /* I have a logic where a semaphore waits for key only if a particular condition is not set
    Therefore, I need help re-structuring the code and the logic is shown below. */
    task automatic t1();
        // If the specified number of keys is available, the method returns and execution continues.
        // If the specified number of keys is not available, the process blocks until the keys become available.
        smTx.get(1);
        $display("%t t1 got key", $time);
        -> e1;
           // drive some signals
        @(posedge clk) smTx.put(1);
        $display("%t t1 PUT key", $time);
    task automatic t_other();
        smTx.get(1);
        $display("%t t_other got key", $time);
        -> e_other;
        #20;
        $display("%t t1_other PUT key", $time);
    always @(posedge cond) begin
           t1();
           t_other();
       join_any
       bit[1:0] d; // delay
       bit c; // condition
       realtime r;
      repeat (200) begin
        @(posedge clk);
        if (!randomize(c, d) with {
          c dist {1'b1 := 1, 1'b0 := 4};
          `uvm_error("MYERR", "This is a randomize error");
         r= d*1ns;
         #r;
        cond <= c;
      $finish;
  3. Papers:
Hi Ben,
I do not see how this implements the priority as the events are only triggered but there is no wait condition on them. Is there anything I am missing?
Rereading your initial requirements, I see this. I don’t see the need for the try_get, why can’t you use the **get.**The t1 task is initiated at every transition of cond. The t_other is triggered in my model by the same transition of cond, but that could be triggered by other conditions. I just made some assumptions here.
Anyway, the point I am bringing is that you can trigger a task upon changes in conditions. Note that these are automatic tasks, meaning that they are concurrent, and if cond toggles fast, it is possible to have multiples of these concurrent tasks running, with each asking for a get or put. Maybe not what you need. I am just providing discussions and options for you to consider.
    import uvm_pkg::*;
    bit clk, cond;
    semaphore smTx;
    event e1, e_other;
    endclocking
    /*forever begin
        @(cb);
      if(try_get())
        break;
        @(cb);
    end*/
      // a semaphore waits for key only if a particular condition is not set
      // and once I gather the key, I release after clocking block statement one cycle later.
        if(!cond) begin
           smTx.get(1); // blocks
          -> e1;
        else begin
          // if a condition is set, therefore, it checks in next cycle for the key.
          @(posedge clk);
    task automatic t_other(); // The other tasks not addressed by you
        smTx.get(1);
        -> e_other;
        #20;
    always @(cond) begin
           t1();
           t_other(); // for testbench
       join_any
       bit c; // condition
       realtime r;
      repeat (200) begin
        @(posedge clk);
         r= d*1ns;
         #r;
        cond <= c;
      $finish;
