I have below code to verify frequency with SVA assertion, but it is failing can you help me here. and ‘clk’ frequency is 2Ghz ,1.998Ghz,2.01Ghz, 1.997Ghz(this is output so freq will change)
`timescale 1ns/10fs
module m2b;
property abc;
time current_time;
disable iff (!lock)
('1,current_time = $realtime ) |=> ($realtime -current_time == 0.5ns) || ($realtime -current_time == 0.500500501ns) || ($realtime -current_time == 0.499750125ns) || ($realtime -current_time == 0.500751127ns) || ($realtime -current_time == 0.476190476ns);
check1 : assert property(@(posedge clk) abc
In reply to iamPkumar:
The following works for me
//`timescale 1ps/10fs
module m2b;
timeunit 1ps; timeprecision 100fs;
bit clk, lock=1;
event pass, fail;
initial forever #250 clk = !clk;
property abc;
time current_time;
disable iff (!lock)
check1 : assert property(@(posedge clk) abc) -> pass; else -> fail;
- SVA Package: Dynamic and range delays and repeats SVA: Package for dynamic and range delays and repeats | Verification Academy
- Free books: Component Design by Example FREE BOOK: Component Design by Example … A Step-by-Step Process Using VHDL with UART as Vehicle | Verification Academy
- Papers:
Hi ben@SystemVerilog.us,
Thanks for replay, Can you please tell me what is the role of timescale here,
what happen if we use timeprecision as 10fs ??
timeunit 1ps; timeprecision 10fs;
SystemVerilog uses a discrete simulation event model, which means that time is an integer. It will round a real time value to the nearest specified time precision. The smallest time precision it allows is 1 femtosecond (1fs).
The level of precision you are asking for will not work. The literal time value 0.476190476ns is 476190.476fs. With a timeunit 1ps; timeprecision 10fs;, that value gets converted to 476.19ps. The time datatype is a 64-bit integer, so if you were to store this literal in current_time, it would just be 476.
The conclusion I am coming to is that you should be using some other timing analysis tool for this level of accuracy, not discrete event simulation.
Hi dave,
Thanks for reply,
with mentioned timeprecision = 100fs , am still seeing below issue.
$display(“pass at time %t”, $realtime); else
$display(“fail at time %t”, $realtime);
started at 5045198069fs failed at 5045698069fs
Offending ‘(((((($realtime - current_time) == 500.00000000000000) || (($realtime - current_time) == 500.50050099999999)) || (($realtime - current_time) == 499.75012499999997)) || (($realtime - current_time) == 500.75112700000000)) || (($realtime - current_time) == 476.19047599999999))’
fail at time 5045.698ns
Please post a complete minimal example, like what Ben wrote.
Hi dev, please find the code
module m2b;
bit clk, lock=1;
event pass, fail;
property abc;
time current_time;
disable iff (!lock)
$display("pass at time %t", $realtime); else
$display("fail at time %t", $realtime);
From the above code, can we print $real_time - current_time like below
($realtime -current_time == 0.500500501ns, $display(“Time_period = %t”,$realtime - currenttime) ||
This might be an issue with precision of real numbers which only has 56 bits. But you run you r simulation indefinitely so that the 64-bit integer time loses precision when converting to a real number.
So, is there any other way to check this type of issues?
Look for tools provided by the vendor you are implemented your hardware on.
Hi Above code working with adding of tolerance. but i want to print current_time value on wave. i have tried with multiple examples but not working. can anyone help me?
module m2b;
bit clk, lock=1;
event pass, fail;
time clk_period = 0.5ns
property abc;
time current_time;
disable iff (!lock)
((clk_period <= $realtime-(current_time-0.001ns)) &&
(clk_period >= $realtime-(current_time+ 0.001ns)));
This Mentor/Siemens EDA sponsored public forum is not for discussing tool specific usage or issues. Please read your tool’s user manual or contact your tool vendor directly for support.
