Error in uvm_config_db
I want to create a generic part of uvm_config_db for 2 interfaces, slave and master for that i have :
tb.sv : first module which has specific interface and must be included in my top_tb.sv (top_level)
but when i try to do this i have this error :
(vlog-2730) Undefined variable: ‘slave_interface’****.
(vlog-2730) Undefined variable: ‘master_interface’****.
this the part of code for this both :
for tb.sv (part of uvm_config_db)__
      uvm_config_db#(virtual apb_interface)::set(null, "*", "slave_interface", apb_s0);
      uvm_config_db#(virtual ahb_interface)::set(null, "*", "master_interface", ahb_m0);
for top_tb.sv __
`include "tb.sv"
module top_tb;
    $timeformat ( -6, 3, " us", 10);
    uvm_config_db#(type(slave_interface))::get(null, "", "slave_interface", slave_interface);
    uvm_config_db#(type(master_interface))::get(null, "", "master_interface", master_interface);
    uvm_config_db#(type(slave_interface))::set(null, "uvm_test_top.env.slave_agent*", "vif", slave_interface);
    uvm_config_db#(type(master_interface))::set(null, "uvm_test_top.env.master_agent*", "vif", master_interface);
    run_test() ;
endmodule  : top_tb
In reply to uvm_share:
A few remarks:
(1) in tb.sv we do not see the instances apb_s0 and apb_m0.Do they exist?
(2) your slave_interface is the sam interface as the master interface. This results from the setings in tb.sv
(3) in top_tb your settings are wrong. The first 2 uvm_config_db shoule be like this:
uvm_config_db#(virtual apb_interface)::get(null, "", "slave_interface", slave_interface);
    uvm_config_db#(virtual apb_interface)::get(null, "", "master_interface", master_interface);
(4) in top_tb you need also instances for the master and slave interface, respectively.
(5) What is the objective of the uvm_congig_db set commands in top_tb?
It is a little bit confusing what you are coding.
Please explain in some more detail what your objective is.
Thank you for your answer so, my objectif is to make generic uvm_config_db , for this i instaciate it by master and slave interface.
  1. i have the instance of apb_s0 and ahb_m0 in my tb.sv
2 ) i have apb as slave interface and ahb as master interface
  1. i tried it but i have the same error
  2. when i instanciate my master_interface and slave_interface i didn’t resolve the error
5 ) as I had a bridge-specific config_db in tb.sv, and I want to make a generic part in top_tb.sv
Oh I have overseen the ahb and apb interface.
But you need the interface declared when putting the interface through the config_db.
Yes, thats what i did, i intanciated like this in tb.sv:
apb_interface slave_interface ;
ahb_interface master_interface ;
This declaration requires brackets like this
apb_interface slave_interface();
ahb_interface master_interface();
So much missing code… Here is a complete working example.
interface apb_interface;
  logic clk;
endinterface // apb
interface ahb_interface;
  logic clk;
endinterface // ahb
module tb;
  import uvm_pkg::*;
  apb_interface apb_s0();
  ahb_interface ahb_m0();
    // ** Use scope of (null,"") to match the get() call
    uvm_config_db#(virtual apb_interface)::set(null, "", "slave_interface", apb_s0);
    uvm_config_db#(virtual ahb_interface)::set(null, "", "master_interface", ahb_m0);
endmodule // tb
module top_tb;
  import uvm_pkg::*;
`include "uvm_macros.svh"
  virtual apb_interface slave_interface;
  virtual ahb_interface master_interface;
    run_test("no_test") ;
class no_test extends uvm_test;
  `uvm_component_utils(no_test)
    super.new(name, parent);
  task run_phase (uvm_phase phase );
    `uvm_info("HELLO", "WORLD", UVM_MEDIUM)
Yes, thank you for your all answers.
So when i try this code :
module top_tb;
  import uvm_pkg::*;
I have a error when i want to simulate like it doesn’t find the port to connect interface ahb and apb
Which simulator you are using?
The code works with VCS and Questa and fails with Xcelium and Riviera. Both simulators cannot deal with
And I do not see what the benefit is of using
instad of
Thanks for your interaction,
my final objective is to develop unified verif env , for this i need to have a stable part of uvmconfig_db which muste be generic for each interface master and slave. that’s the reason why i declared both types : master and slave
For my simulator, I’m using Questa
But you cannot reach it. You have to declare the master/slave interfaces explicitely in your top_tb.
See here:
module top_tb;
  import uvm_pkg::*;
And this is my example on Edaplayground:
Thank you Sir, it is solved Now
